GMHTP - Standing Mile build (88mm, 370... 200+mph)
Old 05-30-2012, 12:36 PM
  #81
TheLS1Lover's Avatar
Originally Posted by TrickrTreat
Not sure if this is a DUMB question , Since nobody has asked but .....What are the notches in the Downpipe and Wastegate exits for? Ive never seen that before and it looks like they were very specific and very planed cuts.
To flow with the lines of the hood.
Old 05-30-2012, 01:43 PM
  #82
TrickrTreat's Avatar
If your right then it was a dumb question but considering the pipes will be sticking through the Hood at least 1/4 inch I'd assume they would have smooth "slash cuts". Those notches I'm referring too wont flow with the Hood lines at all.
Old 05-30-2012, 04:40 PM
  #83
SKULL's Avatar
what are the details on the long block??? what size heads and pistons? are you having parts of the motor ceramic coated like killerls1 did
Old 06-11-2012, 02:19 PM
  #84
LS1Tech Sponsor
Justin@GMHTP's Avatar
Phew, we're starting to make some real progress now. Spent last week up at Vengeance Racing working on the roll cage and let me tell you; Jey Clegg is the man. Check out these welds!
I can't really give out anymore information at this time (check an upcoming issue) but I will say that SALT is looking better than ever. Next stop is the engine dyno!
Old 06-11-2012, 02:21 PM
  #85
Reject's Avatar
Can't wait!! This is one of my favorite builds
Old 06-11-2012, 02:23 PM
  #86
LS1Tech Sponsor
370 cubic-inch iron block (LQ9)
Custom 4.030-inch Diamond pistons, Moly coated tops, ~10.5:1 compression
Lunati Pro-Series 6.125-inch rods
Lunati Pro-Series 3.622-inch crank
Total Engine Airflow / Trick Flow 235cc heads, solid roller
Proline / Steve Petty solid roller camshaft - .750/.750 lift
Old 06-11-2012, 02:39 PM
  #87
deeloc1's Avatar
What are you guys doing for head gaskets using the tfs 235's? Cometic?
Old 06-11-2012, 02:49 PM
  #88
LS1Tech Sponsor
ZR1 head gaskets from Scoggin Dickey Parts Center...
Bottoms Up - The bottom end build.
Top Down
- The top end build.
Old 06-11-2012, 03:22 PM
  #89
deeloc1's Avatar
Top Down
How are you guys able to use zr1 gaskets??? I thought that trickflow recommends at least a 4.125 gasket with the tfs 235's on a lq9??? I'm not trying to bash your thread at all...just trying to make sure I can use the zr1 gaskets on my build...lol! DUDE, if i'm able to use those gaskets (zr1's), these cometics are going right back to Summit! Lol!
Old 06-11-2012, 03:41 PM
  #90
LS1Tech Sponsor
Both Vengeance Racing and Pro Line Racing are comfortable with the ZR1 gasket on a 4.030 bore and TEA/TFS 235cc head, so it is what we're going to run. Not sure on the 4.125-inch recommendation from Trick Flow (can't find that on the site) but I don't see any reason why a ZR1 head gasket wouldn't work on your application...
Old 06-11-2012, 03:44 PM
  #91
deeloc1's Avatar
Cool, thanks man! Cometics are getting returned ASAP! Nice build btw!
Old 06-11-2012, 03:48 PM
  #92
LS1Tech Sponsor
You may want to call up Trick Flow (or Vengeance) before sending them back... they know much more about the heads than I do and I would hate for you to have an issue!
Old 06-11-2012, 05:30 PM
  #93
deeloc1's Avatar
I called Vengeance and Hinson Motorsports and they said the ls9 gasket could be ran with tfs 235's. I emailed Mike @ TEA and asked again, just to be sure...he's the one that told me i needed a 4.125 gasket If running the heads on my stock cube lq9 (364ci) a few months ago.
Old 06-11-2012, 06:01 PM
  #94
KILLER-LS1's Avatar
Hopefully you guys can come out to the mojave mile out here in CA!
Old 06-11-2012, 06:19 PM
  #95
Tiago's Avatar
those are some bad *** welds..
Old 07-19-2012, 07:20 PM
  #96
deeloc1's Avatar
Updates?
Old 07-20-2012, 12:41 PM
  #97
LS1Tech Sponsor
Haven't been up to Vengeance in a little bit (since we did the cage) but we've got a lot of stuff in the pipeline. The transmission has arrived and we're working on getting the engine (back) together for the engine dyno.
I will let everyone know when the next story hits the newsstands and be sure to get some teasers of the other parts along the way!
Old 09-25-2012, 09:57 AM
  #98
LS1Tech Sponsor
Vengeance Racing sure does know how to build a tight cage!
Read More on our site or in the November 2012 issue
Old 09-25-2012, 11:37 AM
  #99
KILLER-LS1's Avatar
Are those the seats you will be using? If not, you might have a hard time fitting a large bolstered race seat in there, I had to change my door bar to be very low to the ground as it passes the thigh bolster to get a Cobra Suzuka Pro to fit in there.
Old 09-25-2012, 12:36 PM
  #100
LS1Tech Sponsor
No, we will be using a set of race seats when it hits the mile. Luckily, we had a spare there for fabrication so the door bars should clear. Good looking out though, that would have sucked to re-fabricate!
Quick Reply: GMHTP - Standing Mile build (88mm, 370... 200+mph)
