K-member for turbo.. can UMI k be used?
Old 01-11-2012, 11:56 PM
Raptor_WS6's Avatar
Default K-member for turbo.. can UMI k be used?
i know BMR makes a specific TURBO K-MEMBER
but i want to stick with UMI since all my suspension thus far is UMI (i know.. i know.. its just a preference)
Does any one have a Truck Turbo or any turbo kit with the UMI unit?
Old 01-12-2012, 12:02 AM
WS6HUMMER's Avatar
Sure there is a way it could be done, some have even done it with grinding/cutting on a stock K-member. I used the BMR turbo K-member, wanted to drop a few pounds anyway.
Old 01-12-2012, 06:33 AM
87silverbullet's Avatar
It all depends on your kit. If it fits a stock k-member it will most likely fit any aftermarket k-member. The BMR will gain you a little clearance over other k-members. Alot of guys have used the PA racing and UMI k-members with good success.
Old 01-12-2012, 08:21 AM
UMI Performance's Avatar
We do know the APS kit works with our K-member. If you are running a single turbo there is no issue and twin will work as well. The turbo k-members offer more room for larger downpipes. But we have seen a lot of APS systems with our k-member.
I hope that helps!
Ryan
Old 01-12-2012, 08:40 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
It really depends on what size down pipe you want to use on your set up. We have gotten as big as 5" down pipe to work with our turbo k-members. Our BMR turbo k-members will give you more clearance and free up a few pounds off the front of the car. If you have nay questions I can help you out with let me know.
Thanks,
Kyle
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 01-12-2012, 10:26 AM
BMR Sales2's Avatar
Here are a couple pictures of the two k-members to show the differences between the two.
Attached Thumbnails K-member for turbo.. can UMI k be used?-ls1-umi-compared-bmr-turbo-k-member.jpg   K-member for turbo.. can UMI k be used?-ls1-umi-compared-bmr-turbo-k-member-2.jpg
__________________
Glenn ***
Sales Tech
813.986.9302
Old 01-12-2012, 10:32 AM
Those pictures do a good job of showing the difference in clearance.
However just a note on picture #2, because of our tube design our k-member sits higher when on a surface. To get an accurate comparison the BMR k-member in front would need lifted about 1-1/2" for a more accurate comparison.
Just a little nit-picking on my end
Old 01-12-2012, 10:41 AM
Stangkilr's Avatar
I have a 4" downpipe running through my UMI k-member.
Old 01-12-2012, 11:07 AM
smokinHawk's Avatar
and i have a 4" downpipe running through my nonturbo style bmr kmember.
Old 01-12-2012, 07:38 PM
Raptor_WS6's Avatar
Thx guys
really appreciate it
im gathering parts for a truck manifold TT set up and want to run 3" down pipes through each side of the motor through the k
if that makes sense lol
Old 01-12-2012, 09:44 PM
WS6HUMMER's Avatar
Did you route yours outboard of the bars that go up to the frame? I've seen some that go outside those bars (closer to the lower control arm) unlike the BMR turbo K-member.
Old 01-12-2012, 09:46 PM
WS6HUMMER's Avatar
Thx guys
Oh I think you'll be good, that should be pretty easy.
Old 01-13-2012, 06:48 AM
Need_a_Camaro's Avatar
Me too. It's tight, but it works.
Old 01-13-2012, 07:08 AM
smokinHawk's Avatar
inward, it was a tight fit but i got it in there.
Old 01-13-2012, 08:18 AM
tripblackls1's Avatar
Bmr how strong is the turbo k vs a standard k , I currently have a umi k and would like to upgrade to the turbo k but I also do roadcoarse and canyon driving and don't want to lose any strength
Old 01-13-2012, 08:48 AM
WS6HUMMER's Avatar
I have a BMR, you can jack the car up on it if you want, have a 4" DP right now and gonna do a 5" on my next build (FWIW).
Old 01-13-2012, 09:11 AM
BMR Sales2's Avatar
The strength between our normal BMR k-member and our turbo k-member are pretty much identical. You won't have any issues using a turbo k-member for doing some road course and other handling oriented driving.
__________________
Glenn ***
Sales Tech
813.986.9302
Old 01-31-2012, 10:16 AM
Somebody09's Avatar
I hope that helps!
Ryan
I have the APS kit with UMI's k-member. It works so damn well that I can't wait to sell it to some other poor sucker and get BMR's. I'm sick of my intakes sucking shut!!! And no matter what, UMI refuses to create something similar to the "BMR-APS" hybrid K-member. I shouldn't have to beg, you know?
Old 01-31-2012, 11:38 AM
BMR Sales2's Avatar
When you are ready for a BMR "APS" k-member give us a call.
Kyle
__________________
Glenn ***
Sales Tech
813.986.9302
Old 12-19-2012, 08:35 AM
Punisher_ws7's Avatar
i am interested in this as well.. i have a UMI non-turbo k member and wanting to run a 4" dp with a single front mount down passanger side... i was wondering if i can do it with the UMI or can i get the BMR-turbo and use my UMI upper and lower control arms
Quick Reply: K-member for turbo.. can UMI k be used?
