LQ4 Turbo Build Thread
Old 05-08-2012, 07:07 AM
RedMilleniumZ28's Avatar
Alright thanks for the info... And does your cooler have all the piping?
Old 05-08-2012, 07:29 AM
Taubr Unit's Avatar
No prob, I'm building the same lq4 but with a s480, click link in my sig for my build thread on what I did with my motor to kill time. And my intercooler is just the cooler, no piping
Old 07-12-2012, 02:58 PM
Alright guys its been a while that iv posted but hope this with catch me up with you guys!
Got All bearings, pushrods, ARP rod bolts and Head Studs, LS9 Gaskets, LS2 Timing Chain, High volume oil pump, Patriot xtreme springs, 4l80E transmission, Cleaned and install everything i have so far!
Old 07-12-2012, 05:15 PM
Richard Tyler's Avatar
looks like its gonna be pretty sweet, i'm building a similiar build on an lq4 force inducted with a turbo. I'm a lil lost. But i'll piece it together.
Old 07-12-2012, 06:53 PM
Brdlvr's Avatar
Looks like everything is coming along pretty good sir! What college are you going to in Lima?
Old 07-12-2012, 08:02 PM
University of northwestern Ohio.
Old 08-06-2012, 01:16 PM
Hivelocit's Avatar
Liking the build! I'm going almost the same route, but in an 88 GMC truck. What were your cam specs? Also did you consider upgrading to the Comp Cams Trunion bearings? Just a little insurance for a small price. Good luck with your build will be sweet when done!
Old 11-02-2012, 09:08 PM
jrpimp00's Avatar
Updates??
Old 11-03-2012, 11:14 PM
One step forward two steps back! So I got the LQ4 fully put together and me and a buddy swapped it in a weekend. I spent about 30 minutes getting it to run and idle in the driveway. So me and my buddy took it for a test drive everything was good till I looked down at my gauges and and I went from 70psi of oil pressure to 10psi so I got her back home and changed the oil and it came out silver So the swap begins again! Pulled the LQ4 out got new head gaskets and oil pan gasket and put the heads cam and intake on the LS1 to go back into the car!
I haven't looked far into the LQ4 yet but Numbers 3,7,and 8 rod bearings are Destroyed along with the crank journal... YAY!
LQ4 Swap
LS1 OUT!
My Buddy
LQ4 Going In
Getting Ready for First Start
finishing final steps
LQ4 is back out again YAY!
LS1 back in and running!
Old 05-30-2013, 11:00 PM
NLA
NLA's Avatar
2jz no **** lol nice build so far man good luck
Old 09-12-2014, 06:59 AM
ABMTex2007's Avatar
Any update on this?
Old 09-17-2014, 07:03 PM
  #32
Build has been moved to a new thread due to how much the build ended up changing. S476 Millennium Build
Quick Reply: LQ4 Turbo Build Thread
