Procharged Daily Drivers in here!
Ok, I've searched in the Forced Induction section along with the Gears and Axles section and found no help.
What rearend gears are you running? I have 3.70's in a MWC 9" I'm also an Auto (4L65E). Curiour what type of MPG you are getting? I drove the car for a week straight on vacation and got anywhere from 11.5mpg to a best of 15.4mpg. Mostly interstate driving 75-80mph, the 11.5mpg was from playing with a few cars.
Details: AES 390cu in @ 9.25:1 CR D1SC with 7.65"/3.55" pulley, SS3600 Yank Stall, FLT Stage IV trans, MWC 9" 3.70's Standard tire size.
Thanks,
Ken
Thanks,
Ken
Doesn't make sence to maybe go with a larger rearend gear like a 3.25 or 3.00 to bring the rpms down? Or step up to a 28" tall tire? The car isn't a daily driver however I do like to drive it accross country. My last trip was about 3500 miles and cost me about a grand in fuel. Thanks for the help!
I'm not a mpg expert, so this opinion is probably worth as much as you paid for it.
I don't think you'll notice much of a difference, if any.
Even with my supercharger off I still get 14 mpg. The biggest drivers I have found that affect my gas mileage are the tune (I run SD open loop), my cam, and my compression (I run 8:1)
If you are open loop then there may be some mileage to be gained by putting in a couple forward O2 sensors and getting the car back to closed loop.
If you are SD closed loop though, then there likely isn't much you can do to the tune to pick up any noticeable differences in gas mileage.
I'm on the stock long block and 3.42 rear. I have an SD tune that I spent alot of time on as well. I was rich on decel with the 60lbers and tuned my DFCO to be more aggressive and that gained about a mile to gallon or so in town. Turned LTFT off still have STFT on. From what I understand you can get "Hotter O2's" which read more accurately in long tubes. Some people also take out too much timing down low with these setups. Low load and low compression can tolerate a lot of timing even with FI just make sure the spark transitions into boost are correct. Only way to tune for sure is a spark hook test or a great deal of trial and error.
UNDER PRESSURE MOD
Mostly due to traction issues. As soon as I roll into the throttle enough in first and second to close the bypass valve, the torque just blows the tires off. Plus the gears feel so short with the extra power.
I'm going to try and run a slightly taller and wider rear tire and see if that helps for now. I'm going to go from a 275/30/19 to a 295/30/19 and see what happens.
I don't know what kind of tire you are running, but I was going to do the same thing (swap back to 3.42's) until I switched to Toyo Proxes R888 tires.
They stick like paint and aren't suicide in the rain.
My car will firmly plant 3rd on a hot day.
I've been through a ton of different types of tires and I've had this tire on for 2 years now with great results. The only thing stickier that's been in the back are slicks and MT's - and both of those were suicide on wet roads.
UNDER PRESSURE MOD
I'm happy to hear that the R888's are good tires. I'm currently rolling on Michellin Pilot sport tires that are a few years old, so they are probably getting a little hard at this point.
I think a new set of tires is in order for me.
As for mileage, I was seeing 17-19mpg city driving with the procharger on last year. Mostly shifting between 3000-4000 rpm since I had plenty of torque and didn't need to push the revs. I actually didn't notice any change in my mileage with the procharger, well, except when I was out having fun, then the mileage dropped considerably, but what do you expect when you're maxing out 60# injectors.
Lol put a real tire on the car and you won't have traction problems!
