Will my cam be ok for boost
Old 06-18-2012, 07:24 AM
cory32690's Avatar
Default Will my cam be ok for boost
I have a 01 formula with 166k I'm wanting to do a 6.0 swap make it a 370 wiseco pistons and k1 rods
I already have a 225/229 581/591 114+4 cam in my ls1 will my cam and stock 241 heads be ok for boost..I no it has alot to do with the tune but was curious how this cam will react to boost until I can order a spec cam for it
Old 06-18-2012, 07:41 AM
Beanslsxnova's Avatar
That cam should be fine. But as far as the heads go. I would run the 317's that come on the 6.0
Old 06-18-2012, 09:15 AM
mconway68w's Avatar
^ Agreed. But why not have one custom ground if you're already taking on the project? Selling your current heads and cam would nearly pay for the difference.
Old 06-18-2012, 09:38 AM
cory32690's Avatar
My budget is getting tight and I'm wanting to get the motor in and get it runnIng...I've been looking at the 317s probably will grab a pair if budget allows and like I said I'm going to get a custom ground but i need to get the motor in the car and broke in
Old 06-18-2012, 10:28 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
The money you save now by not doing the cam, will be twice as expensive to do later, plus the time and labor to do it later as well.
Old 06-18-2012, 10:53 AM
87silverbullet's Avatar
I'm the kind of person to say run what you have. That cam does not look bad, its not like its an MS4 or something. It has a good separation on it and on a boosted application for the street you are better off under camming it.
As for the heads the 241's are a smaller chamber so you will just have to get pistons accordingly.
I look at it this way, if I'm just throwing it together to have some fun, run what you have because it will still make power on boost. If I'm going to really try to make some real power to go to the track and run some single digits then I would be going about finding a better cam for boost and worrying about heads.
Old 06-18-2012, 12:00 PM
postal14's Avatar
That cam should work good in FI. It would probably make a better turbo cam than a SC cam, infact it would probably be a damn decent turbo cam. You should state what type of FI you are going to use.
what compression ratio do you want to run? Wiesco makes a piston that would get you 9.5 to 1 with your 241's and LS9 head gaskets. That piston has an 11cc dish and is the K444X (then add S,05,3 to the end for standard, .005, or .030 over). If youre wanting to run closer to 9.0 to 1 then wiesco doesnt list a piston for you that would work with your 241's and LS9's. The next dish size is 25cc, if you ran these with 241's you would drop all the way to 8.4 to 1. I made a little spread sheet program I just plug a few numbers in and one of the things it calculates is compression ratio. It would be easier if you said what compression ratio you wanted, and also if you want to run LS9 head gaskets or cometics. They make a few diff thickness cometics that can help you tweak your CR but the cometics are a little pricier.
Overall your post / question is to generic. Include other details to like hp goal intended usage ect. You will be able to get more specific feed back.
Old 06-18-2012, 12:46 PM
I8UR4RD's Avatar
its fine. not perfect but not half bad. i took out my 228r to add the blowe cam, and it was fine to start with too. i just wanted max results.
if you want a blower cam, most run 389 shipped. different ones to choose from too. all depends on your setup and what you want from it.
Old 06-18-2012, 08:23 PM
Fbodyjunkie06's Avatar
What type of forced induction? Turbo or blower?
Old 06-19-2012, 06:46 PM
I8UR4RD's Avatar
must be a Tornado, because he aint saying is he lol....
Quick Reply: Will my cam be ok for boost
