bone stock 5.3 s472, when should i stop
So i have 100% bone stock internal 5.3, FAST 102mm intake/TB, 80lb injectors with FAST rails, 60mm jgs wastegate, truck manifolds flipped with custom crossover front mount t6 s472, a1000 external pump, 3inch hotside/ 4 inch coldside FMIC...
Have almost everything to throw the car together and im wondering where i should have the tuner stop when it comes that time. I am building forged motor with cam and springs so i can just swap accesories over and retune for ton of power. I am not opening this motor up at all. Im putting moroso pan on it so it fits in the car and thats it.
Looking to still have some fun with it when im driving it around. Probably couple tracks days tops before the new motor would be finished. Cars 2800lbs and th400 with 3800stall. 450ish???
Sorry, turbo to front mount is 3" front mount to TB is 4"... its 2.5" vband on manifolds and 2.5" pipes into merge then t6 flange.
Even with stock cam the valve springs get sketchy?
Wow good to know... anyone have link to good known springs? Mabe ill have to do the good springs now and just reuse these heads. So no junk springs. Need some good know springs to not give any issues.
Do you have PN for the lunati springs? I guess ill pick those up and they should be good when i get a turbo cam later on. Need them for the 5.3 heads.
get good ones..i found this out the hard way.. i bought some springs that are rated to .600 lift .. but only had 105 seat pressure... the ls6 springs had more seat pressure than this.. now i have to do this a second time.. with some duel springs.
Idk the part number. Just look up "lunati dual springs ls1" on eBay.
yes 1218s from scogg and dickey auto parts are like 140 dollars and will handle a decent sized cam and 22lbs of boost, and even a 125 shot on top, i promise.
you might be able to make 12lbs or so on stock springs. ive done 16lbs on stock springs but it kills them fast and the powerband of the car will go to dogshit
just do springs and hit it with 20lbs
ive tried them all in a row on the turbo truck
