Rear Mount Tubro, why and why not? Gurus on the subject appreciated
Ok this is the list that I think I need to build my own turbo kit
Turbo:
-On 3 Performance 76mm Turbo Camaro LS1 LS2 LS3 LS6 LSX Camaro Trans Am 6.0l 5.3l
Wastegate:
-OBX Racing 38mm Delta Wastegate Turbo Turbocharger 38MM
Oil Pump:
-The Mocal 12v Oil Pump
Blowoff Valve:
-HKS SUPER SQV 3 BOV SSQV 3 SEQUENTIAL BLOW-OFF VALVE
Couplings and Transitions
-(4) 2-1/2" Verocious Silicone Coupling Turbo Hose, 3" Long, 4 Ply Aramid, Blue
-(1) Universal Blue 3.0'' to 3.5'' 3-Ply Reducer Silicone Hose Coupler 76MM to 89MM
-(1) Universal Blue 3.5'' to 4.0'' 3-Ply Reducer Silicone Hose Coupler 89MM to 102MM
T Bolt Clamps:
Flanges:
-Tubro Flange, wastegate flange, bov flange, exhaust and oil flanges
Oil Feed and Return Lines
Check Valves
Boost Gauge
what else needed im all ears
Turbo:
Wastegate:
Oil Pump:
Blowoff Valve:
T Bolt Clamps:
Flanges:
Check Valves
Boost Gauge
They can work well for drag racing as you have time to stage the car and build boost.
For the street, I've never driven a rear mount setup that I've liked. Just not responsive enough at tip-in and transients.
Is it complete? I like my rearmount but tomorow when I go to the track will be the real test,one thing I have to say tho is the car feels alot faster with the 2.73 vs the 3.42 I had before.this time I just gotta remember to not do no lift shifts
Honestly it just depends,im running a 6speed and the 2.73 gears are great. First pulls real hard now where it didnt before.I wish I would have made it to the track with the 3.42s. Out of boost the car is a little weak but it also builds boost so much faster now. In my fox im planning on using 3.08 gears with a glide.id think 2.73 gears in a a4 would be best of both sorlds
I had a rear mount it had to many problems for me. but i made the kit its all on me. the sts kit will work way better then the one i made. Try modular turbos kit. I am running it right now. looks all most stock under the hood not much lag
https://ls1tech.com/forums/forced-in...ing-799-a.html
That's really not bad for the money,which turbo? Mine ran great at the track last night.i have not had any issues with my rear mount,im just braking stuff now.first my 10bolt now my lq4 as of last night,car trapped 123 leaving like I was leaving a stop light then I got froggy and turned the boost up 1psi with out adjusting my tune, needless to say the motor detonated and took out a piston
#35
I imagine an M6 would have a little lag at low rpms though.
#36
There are a ton of myths on here about what to do for rear mounts.
I have LTs dual 2.5" ex and twin pte billet 5858s and the responsivness is crazy. It makes power at any rpm and is almost instant.
The car made 876/860 on 18psi pump and meth with more to go. It should make 1k on good gas
One thing to think about is the 400 $ oil pump you dont need if you go oil less. So you can just put that 400 $ s into the oils turbo
#38
LS1Tech Sponsor
That would make a big difference as the standard ground clearance has always been a problem with these kits. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
#39
