6.0 cam/intake only and turbo ?
Old 08-03-2012, 09:27 AM
Boosted Firehawk's Avatar
Default 6.0 cam/intake only and turbo ?
how many guys on here have a stock longblock minus intake and cam.
I wanna run a ls6 intake and ported throttle body with my s475 and wondering who has done it?
what head gaskets should I use? arp head studs, part number I need to?
HOw much power are you making and how fast are you?
Im trying to figure out if it will be worth it.
Id like to do a ls6 intake and cam with lifters and valve springs. Thats it and no more extra items. THen add the turbo and turn up the boost.
Old 08-03-2012, 11:44 AM
typhoon1015's Avatar
i have a cam/valvesprings, intake, rod bolt'ed stock 6.0 head studs and LS9 gaskets
767hp @ 6200 15.5psi boost on E85. thats through a stalled 4l80 and 12 bolt
Old 08-03-2012, 12:36 PM
LS1NOVA's Avatar
That Pro-Flo XT is definately helping your stock shortblock make killer power. I wonder if anyone has done back to back testing from LS1 to LS6 to Pro-Flo. Maybe I should hit up some vendors and do a little dyno article.
Old 08-03-2012, 04:33 PM
there you go!
I think lower boost it doesnt matter much but when you get up to higher air flows is where it really shines. I just thought it looked cool, and was super cheap compared to a fast or ls6 etc
I would like to do a Holley but at 12 inches high, it wont clear much, the pro-flo is only like 10 something i think.
Old 08-03-2012, 09:46 PM
any part numbers on the pro flow
Also what is the compression on the stock lq9 that you have with ls9 head gaskets?
What heads are on your engine?
Old 08-03-2012, 10:24 PM
i have a lq4 9.4-1 compression, stock 317 heads
check out edelbrocks site for pro flo information- dont remember PN off the top of my head.
Old 08-04-2012, 11:33 AM
831jd's Avatar
Are u ^^^^ running the s475 1.10?
Old 08-04-2012, 11:44 AM
buick_lsx's Avatar
i have the s475 with 1.10
had lq4, ls6 cam and edelbrock pro flo...57x rwhp unlocked, 610 locked on 11lbs
new motor is 370 with same heads and intake but bigger cam (same turbo) and made 66x unlocked and 710 locked on 13 lbs
4l80 and s60 rear, pump 93
Old 08-04-2012, 01:16 PM
SO IS THAT THE COMPRESSION on a stock lq9 with 317 heads and ls9 head gaskets?
Old 08-04-2012, 03:00 PM
I have a journal bearing gt4276 with T4 1.10ar
Old 08-04-2012, 03:06 PM
you would have to check differences in compressed thicknesses but im pretty sure they are the same or very close. I want to say compressed thickness of .052 for some reason. They shouldn't change static compression at all.
Old 08-06-2012, 09:09 AM
anyone else
Quick Reply: 6.0 cam/intake only and turbo ?
