Granatelli Camaro Twin Turbo Kit
Old 08-22-2012, 05:51 PM
granatelli sales's Avatar
Default Granatelli Camaro Twin Turbo Kit
A detailed break-down of the 2010-2011 Camaro Twin-Turbo kit and its components are as follows:
2 x PTE6265 Turbochargers with 4” Inlet Compressor ducting – Each capable of 65 lbs/min
Turbos are V band mounted on inlet and outlet to insure easy rotation, solid mounting and best of all there are no nuts and bolts entering or exit turbo body
2 x PTE 46mm Waste Gates Insure Maximum Control Over the Monster Turbos. Waste Gates Include Adjustable Springs to go from 4.5psi to 15psi (We factory set them at 7lbs)
All stainless steel and Heat temperature coated exhaust system components ensure a lifetime of reliability
1 x 50mm Tial Blow Off Valve
3 x Largest Front Mount Intercooler are Hi flow Bell cores with 3.5” inlets from turbos and a single 4” discharge pipe feeds direct to the throttle body. Intercooler Tanks are Black Powder Coated to Extract Heat Yet Fins Remain Untouched
Fiberglass Reinforced Silicone hose couplers ensure durability for year to come – no expense was spared
All the necessary Vacuum ports required to assist in installing the boost controller
1 x Oil Scavenge Pump & Brkt
Thermal Heat shielding for all effected lines
GMS Oil Feed & Return Line Kit are all precision clamped and crimped to ensure leak free connections
GMS/TTi 3.5” 6061 Aluminum Intercooler Tubing for lighter weight and better heat dispersion
GMS/TTi 4” 6061 Aluminum Charge-pipe
GMs/TTi 4” Aluminum Intake Tubing w/K&N Filters and K&N “Hydro Shields” for extended dust/dirt/water protection
GMS/TTi Aluminum Lower frame cover to ensure debris free road travel
The only TT kit that does not hang below the frame rail, ensure plenty of ground clearance
AEM Windshield Washer Bottle & Accessories
Polished Oil Cap w/oil return
Retains Factory Engine Cover
We offer many options from short blocks and long blocks to various turbo size upgrades and color choices. Factory Silver Powder Coated Tubing – Special Colors Available on Request.
This is the dyno sheet of the base turbo kit you can get
We can build it as a mild ride
all the way up to a wild ride
Old 08-23-2012, 03:12 PM
fatmat80's Avatar
will this kit fit in a 2009 g8 gxp? if not is there a kit for the g8? either now or on the horizon?
Old 08-23-2012, 04:05 PM
N2OBaby's Avatar
Compound Boost like a TVS type Blower and 1-2 Turbos???
Old 08-23-2012, 07:47 PM
fastsspr's Avatar
interesting
Old 08-24-2012, 10:40 AM
It has twin 62mm turbos and holds up to 1200 hp
Old 08-24-2012, 11:22 AM
MaxxMitchell's Avatar
Has anyone touched a 1000rwhp with just the 6265s and your kit?
And also can 6765 or 6766 cea be installed in place of the 6265s?
Old 08-24-2012, 12:46 PM
Sorry no a 6765 / 6755 does not fit. Our kit was designed for the customer looking for 100,000 miles at 1200hp at the crank. We have Corvettes that do it all the time. I know of 3 camaros that have reported over 1000 rwhp with our kit but I have not seen it here. I have dyno'd 2 Vettes myself that made over 1000hp and 1000 ft/lbs using the same turbos from our vette kit.
We can build anyone custom kits that will go sky high - you pick the power you want. Our off the shelf kit is a real 600+ hp kit at 7psi on a Vette or Camaro and 850 at 10 to 12psi. If you want more power and run race fuel, 16 to 18 psi gets you to 1000
I am sure everyone has seen our video of the compound boosted Camaro engine. The blower just gets in the way of the turbo, it would make more power without the TVS2300 in the way.
Old 08-24-2012, 01:54 PM
NemeSS's Avatar
Does the fmic/plumbing cause any over heating issues??
Looks like a quality kit
Old 08-24-2012, 04:08 PM
No, We have put this kit on numerous amount of car and none have even gotten close to over heating
Old 08-27-2012, 10:55 AM
Just Dyno a Camaro with our TWIN TURBO system make 650 hp on 8ps
Old 08-29-2012, 12:05 PM
Any Questions
Old 08-29-2012, 03:00 PM
stevieturbo's Avatar
Images in the first post dont work for me ?
Old 08-29-2012, 03:41 PM
DaGreightOne's Avatar
Yeah what he said...
Old 08-29-2012, 05:18 PM
Look at it now it should work
Old 08-29-2012, 05:28 PM
Looks very neat !
Old 08-30-2012, 05:08 PM
All pictures work now
Old 08-31-2012, 11:36 AM
Just dyno another Granatelli Twin Turbo System it make 670 rwhp.
Old 08-31-2012, 05:38 PM
Any Questions ANYONE
Old 08-31-2012, 05:42 PM
Ironmancan's Avatar
What is the exhaust AR size your using on the base kit?
Old 08-31-2012, 05:43 PM
Ironmancan's Avatar
Btw this looks like a beautiful kit.
Quick Reply: Granatelli Camaro Twin Turbo Kit
