Why is a 5.3l w/317 a slug?
Old 09-09-2012, 08:32 PM
RiDgeViStaRider's Avatar
Default Why is a 5.3l w/317 a slug?
Just woundeing why, the 5.3L with 317 heads make a T76 feel like a slug off the line but pickup top end?
Old 09-09-2012, 08:38 PM
anheuserbusch08's Avatar
ur lowering the compression way beyond what ull actually need. ive seen 5.3s with ls1 head making fantastic results
Old 09-09-2012, 08:40 PM
Cam72aro's Avatar
^^^^ What he said. It lowers compression.
Old 09-09-2012, 09:08 PM
Burken01's Avatar
What compression? If it's super low then turn up the boost. Low boost and low compression makes a car sluggish... 9.5:1 cr will give decent drivability while not in full boost..
Old 09-09-2012, 09:15 PM
got-a-ls1's Avatar
yea dude 317's on a 5.3 is extremely low compression.
Old 09-09-2012, 09:36 PM
runninfromthelaw's Avatar
317's are 71cc chamber so it drops a 5.3 down to 8.5:1cr. Stock 5.3 862/706 are 61cc and 9.5:1cr
Old 09-10-2012, 07:40 AM
Sarg's Avatar
depends on the 5.3 also. The L33 uses flat top pistons instead of dish.
Old 09-10-2012, 09:58 AM
pwrtrip75's Avatar
What engine with 8.6:1 compression isnt a slug? People are under the impression that turbos need low compression. Probably true if you are trying to run 30psi on pump gas.. But if you had a turbo to achieve that and you are running a stock 5.3 odds are it would fly apart well before that...lol. So no need to lower the compression to prepare an engine for something it will never see. I did this also....it sucked. lol.
Old 09-10-2012, 12:32 PM
milkplus's Avatar
An 8.5 5.3 without a turbo is like a 150-200 hp combo... so there's your sluggish right there.
Do you have data that says a lower static 5.3 with more pressure is more efficient then a 10:1 5.3 with a t76? What makes you think it will "pick up top end"?
Old 09-10-2012, 02:15 PM
Grr
Grr's Avatar
not only that, but it is also usually paired with a cam like a ls6 or 224r, where your dynamic compression is down in the low 6s or high 5s. THAT is the real problem
Old 09-10-2012, 03:32 PM
Ferocity02's Avatar
It makes is a slug when NOT in boost, which for a street car is 98% of the time unless you're Vin Diesel
Old 09-10-2012, 04:06 PM
tta656's Avatar
GN's are v6 with 8.5 CR and are not sluggish when not in boost(well not that much) and only rated at 245hp in boost
Convertor stall
Rear end Ratio
Ar. of exhaust housing..
Old 09-10-2012, 04:09 PM
Old School Heavy
speedtigger's Avatar
Convertor stall
Rear end Ratio
As previous owner of 2 turbo Regals, I beg to differ. They feel real sluggish when not under boost. Fortunately they spin up pretty quick.
Old 09-10-2012, 08:58 PM
Burken01's Avatar
can you elaborate on this a little more?
I'm going with a ls6 cam w/317 heads, ls9 head gasket on a 347 with -2cc valve relief flat tops..
I would like 9.5 compression
Old 09-10-2012, 09:17 PM
Grr
Grr's Avatar
that equals out to 9.45 compression and 7.08 dynamic compression.
Old 09-10-2012, 11:27 PM
cjvmboricua08's Avatar
ok so let me see if i get this right... i got a 5.3l with 317 heads, ls6 cam, and flat pistons.. which should be 9.5:1 comp right?? should i swap into ls1 heads for better results or turning the boost up at lower rpms should even it out??
Old 09-10-2012, 11:52 PM
Grr
Grr's Avatar
Actually I used the Ls1 bore for that. Your combo is
9.05 cr
6.75 dynamic cr
That is why they are such dogs. That is a 200whp at best N/A. I would run 241s myself over 317s which is
9.55 cr
7.15dcr
Old 09-10-2012, 11:58 PM
o2camaross's Avatar
Grr, can you explain the dynamic CR and how you calculate the DCR and STR? Thanks
Also, I understand the significance of STR, but what is an ideal DCR for a street vehicle and how does that play into driving or response. Im sure Im not the only one who would find this info useful
Old 09-10-2012, 11:59 PM
i see. understand why prior of the turbo build it only dynoed 329/321. what kind of boost could them 241s hold?
Old 09-11-2012, 12:45 AM
o2camaross's Avatar
ok I looked it up and understand now. Now I just need to figure out when my intake valve closes lol. Would that be on the cam card?
Quick Reply: Why is a 5.3l w/317 a slug?
