on3 76mm feed/drain
on3 76mm feed/drain
Quick question for the guys who have this turbo or have use this turbo. What size is the Feed/drain on this turbo? I'm just trying to order the right fittings ill need. Yes! i searched, and i couldnt find a specific answer.
Only thing i read that came close to specifics was the feed, and i read it was 1/8th, if anyone can comfirm? I believe the on3 feed/drain is NPT though i'm not 100% sure
ya disregard, i'm retarded lol. the listing clearly states
"To ensure the longevity of your turbocharger, we normally run 1/8" feed and a 5/8" return. This is very important and without this properly sized, you can cause damage to the product"
LS1Tech Sponsor
I can get the fittings needed for this turbo if anyone is interested. The drain requires an offset flange to clear the compressor housing and is -10an. The feed line has a built in restrictor for the turbo and is -4an
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Im running -3 feed with no restrictor and -10 return. My feed on the turbo was 1/8npt but I got an early unit I believe. My roommate bought 2 of these for his camaro and one was 1/8th and the other was something weird like stated before. Anyway Ive been running the oil like that for over 3000 miles with no problem
I run a -6 and it "Y"s into -4. I did have to ad a restictor. I was getting a little excess oil. Couldn't drain quick enough. I also have -10 drain lines and no restrictions to stop draining. The set up like this I have had NO issues. Runs perfect. No excess smoke, etc...
