Turbos?
Turbos?
So I put a pair of t70's on my stock 4.8l and they seem to be too big. They start to spool around 3000rpm. I am just wondering what size turbos I should go with to get 600RWH with my stock engine and get them too spool earlier? I bought these before I was on this forum and didn't really know what I was buying. Any advice would be appreciated.
I don't remember all the specs, but yes they are the ebay t70s and it says on the houseing a/r70. It was street tuned and they come on very hard at 3000 rpm. I'm using 80# injectors and a1000 fuel system. I zero running problems, I just think performance would be better with smaller/faster spooling turbos. When the car is at idle the turbos even stop turning, thats why I think the stock engine is too small for the turbos.
Unfortunately I bought the HPT basic and it doesn't log. I had the car tuned by someone on the site and it does run great once the turbos start to spool. The wide band stays around 11.5:1 and the tiiming is around 17*.I was told when I first joined and started my build thread the turbos were probably too big. They work they just don't come on till about 3000 rpm. I'll attach a copy of my tune.
You want a pair of T3 turbos, with nothing bigger than 60mm compressor inducers. Even smaller would be slightly better. Like a pair of GT30s. T3 .82 would work well, and so would .63 if you are more concerned with spool( probably about 300 rpms difference).
Here you go;
http://www.turbosource.com/GT3076R-p/ts1-1-65180.htm
Old school To4E 57 trim would work too
Here you go;
