Hit my goal with the car today
Well my main goal for the car was reached today at a track rental at MIR.
Before today By personal best was a 9.4@149mph since then I have added a AMS-500 boost control and worked on the tune some more
First pass off the trailer.
3300 rpm and 6 psi on the brake ramped to 12 psi down track
60' 1.449
1/8 5.995@118.25
1/4 9.300@149.20
2nd pass 3500 rpm and 7 psi on the brake ramped to 12 psi down track
60' 1.185
1/8 5.930@120.09
1/4 9.197@150.66
3rd pass raise the down track psi to 13
60' 1.361
1/8 5.823@121.20
1/4 9.055@152.16
4th pass raise trans brake psi to 8 and raised the ramp rate
60' 1.356 on the back tires. Wheelied good
http://youtu.be/lx1TQo_6HFU
Scared myself a little on that pass so I set the boost controller setting back to the previous pass
5th pass
60' 1.439
1/8 5.896@121.83
1/4 9.109@154.25
6th pass raised down track boost to 14psi
60' 1.383
1/8 5.823@122.42
1/4 9.028@153.28
7th pass raised downtrack boost to 15 psi and made some shock adjustments
60' 1.376
1/8 5.755@123.47
1/4 8.935@154.21 <-- fist 8 second pass and my goal for the car
8th pass I wanted to back the 8 second pass up only shock adjustments made
60' 1.401
1/8 5.776@123.77
1/4 8.94@154.76
9th pass just for fun made some more shock adjustments and raised the 2 set to 3600 and 8 psi
60' 1.358
1/8 5.725@123.70
1/4 8.896@154.86
I am extremely happy with the results of the car for only 15 psi. Also the car weighed 3410 after the 8.89 pass. Here is video of the 8 secon passes
http://youtu.be/ShnKu88lDkY
60' 1.449
1/8 5.995@118.25
1/4 9.300@149.20
60' 1.185
1/8 5.930@120.09
1/4 9.197@150.66
60' 1.361
1/8 5.823@121.20
1/4 9.055@152.16
5th pass
60' 1.439
1/8 5.896@121.83
1/4 9.109@154.25
60' 1.383
1/8 5.823@122.42
1/4 9.028@153.28
60' 1.376
1/8 5.755@123.47
60' 1.401
1/8 5.776@123.77
1/4 8.94@154.76
60' 1.358
1/8 5.725@123.70
1/4 8.896@154.86
Thanks guys. It has been a long time coming. I am glad I could do it on 15 psi and just on E85. I haven't started sparying any Meth. I might hook it up for next year when I turn the boost up more. Now it is time to deside on a goal for next year.
I will also note that the car is going on the rollers Saturday so I can see what kinda of power numbers it is making
There are lots of pics of the car/engine and turbo set up in my build thread that there is a link for in my sig. But the basics are
AES ls2 385 4 bolt
205 AFR heads 10:1 CR
VA Speed VTC2 cam
Vic Jr with an Aaron's elbow and a stock TB
S88 Turbo with a divided 1.32 AR and the kit does feed the turbo divided. I have built and tuned all of it myself minus assembling the short block
AES ls2 385 4 bolt
VA Speed VTC2 cam
