White smoke blowing out of oil cap. Compression test looks good.. Help
Old 11-23-2012, 03:59 PM
AtomicVette's Avatar
Default White smoke blowing out of oil cap. Compression test looks good.. Help
Driving home a couple weeks ago, I came to a stop light, and the car died. I tried to start it and it didn't want to start. Finally got it started but had to keep my foot on the pedal to keep it from stalling. Drove home (about a mile) put it in the garage, there was smoke pouring out from under the hood (from the PCV System and when I pulled the oil cap off some coming out of there)
Well today I finally got around to looking at it. I did a compression test and they all turned out good, 190ish on all cylinders.
No weird noises.
Oil looked fine,
Coolant looked fine.
The car doesn't like to run, I have to keep my foot on the pedal to keep it running.
So what should I check next?
Old 11-23-2012, 05:13 PM
JoeyGC5's Avatar
Gas smell in the oil? Have you checked all the spark plugs and wires? Coolant system staying pressurized?
Old 11-24-2012, 07:41 AM
wild1100's Avatar
What do the plugs look like
Old 11-24-2012, 11:06 PM
kyleholt11's Avatar
If I were you I would do a leakdown test...
Old 11-25-2012, 12:53 PM
plugs are black, car was running way rich before this happened.
Old 11-25-2012, 01:20 PM
BadgeZ28's Avatar
scan? Codes?
Old 11-26-2012, 08:28 AM
no codes
Old 11-26-2012, 09:35 AM
Ryans99ls1's Avatar
ive seen a few cars pop ring lands and still show good compression, they also ran fine too.. might as well pull the heads and check.
Old 11-26-2012, 08:03 PM
runsfromdacops's Avatar
do a leak down and listen with the oil cap off. this will tell you which cyld has all the blow by
Old 11-26-2012, 08:27 PM
JaYZeig's Avatar
my vote is a popped ringland...EXACT same thing happened to me
and come to show number 7 took a ****! i got lucky and had no cylinder
head damage, nor cylinder wall damage...popped a new slug and rings in
and cars been running strong since.
id take a look at particulary cyl 7 and 8 since theyre most prone to getting the
hottest and popping lands.
Old 11-27-2012, 06:11 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
I have too.
To the OP, with white smoke blowing out the oil cap, I would not drive the car until the heads are pulled. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 11-27-2012, 06:16 AM
LS1Tech Sponsor
I agree, and you did get lucky! I've seen cylinder blocks crack in the cylinder wall when the engine is run too long with a cracked ring land. Bob
__________________
Old 11-27-2012, 02:27 PM
Haven't driven it since I parked it. haven't even started it...
Guess I'll yank the heads and see what's up. good times!
Quick Reply: White smoke blowing out of oil cap. Compression test looks good.. Help
