which turbo would you run.
Old 11-25-2012, 08:05 PM
Gfleck047's Avatar
Default which turbo would you run.
I am doing a turbo 5.3 mustang. I am planning on using a tu1 cam. I would like around 650hp 700 hp have a set of 243 heads. I have been looking for a turbo for a few months just can't seem to figure out what I need. I was looking at a s400, a CRT mid frame 88 , gt4082 I believe, tc78. I just don't know what will work good or what will be a waste of money. It Is gonna be a drag car that might see a few miles of street but not a lot.. I wanna keep the turbo below 1200 ... what turbo would you use and why and will the tu1 work good or not? Any advise would be awesome
Old 11-25-2012, 08:31 PM
a4ls2goat's Avatar
ill be doing something similar. i will be going with the S475 T6
Old 11-25-2012, 08:37 PM
RacerXLs1's Avatar
Pt88?
Old 11-26-2012, 04:49 PM
Gfleck047's Avatar
Anyone?
Old 11-26-2012, 07:09 PM
LS1NOVA's Avatar
The price and performance of an S400 is hard to beat.
Old 11-26-2012, 07:31 PM
TexasTarnation's Avatar
^Agreed
Old 11-26-2012, 07:42 PM
code4's Avatar
If you want something small & light for that power level check out my ct80: https://ls1tech.com/forums/parts-cla...bos-cheap.html
Old 11-26-2012, 10:19 PM
T76s10's Avatar
s475 hands down
Old 11-27-2012, 01:49 AM
9 Second Truck Club
stock48's Avatar
Yes I agree S475/83mm for up to 800 hp, if wanting more power or a bunch of rpm go bigger ex wheel.
Old 11-27-2012, 07:48 AM
oange ss's Avatar
TC78 will meet your goals, but wont have room to grow with it, but it is the best bang for the buck
Old 11-27-2012, 07:53 AM
LS1Tech Sponsor
Superman09's Avatar
Keep space and weight in mind as well. an S4series BW will be about twice as physically large and heavy as a TC78 if you have a space constraint.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 11-27-2012, 12:31 PM
Gfleck047's Avatar
I will cut what I have to to make it fit that isn't the issue at all I am cutting the roof off the car tonight so no biggie I just don't wanna build a bigger motor and not be able to run with out a new turbo
Old 11-27-2012, 02:20 PM
LilJohn's Avatar
If you want upgradeability... do the S480 with the 96/1.32.
And get a different cam while youre at it.
Old 11-27-2012, 09:05 PM
Gfleck047's Avatar
Which cam would work running like 10-14 pounds on e85
Old 11-27-2012, 09:19 PM
Blackpanther99's Avatar
I know a lot of people that use 76mm for daily driving
Old 11-27-2012, 09:44 PM
Gfleck047's Avatar
It is not a daily driver it is maybe a once a month driver a mile or two put it backb in the trailer
Old 11-27-2012, 11:20 PM
I would use a 88mm
Old 11-27-2012, 11:43 PM
I need a gauge for that
Atomic's Avatar
I have a freshly rebuilt garret 80mm with a t6 1.39 96mm turbine... would work great. $600
Old 11-28-2012, 05:05 PM
T76s10's Avatar
Hey atomic how much lbs does that compressor wheel flow
Old 11-28-2012, 05:10 PM
T76s10's Avatar
What's wrong with the tu1 cam?
Quick Reply: which turbo would you run.
