~Procharged ls1 f-body 1/4 mile times~
Old 12-09-2012, 07:02 PM
sweet99ss's Avatar
Default ~Procharged ls1 f-body 1/4 mile times~
I can't seem to find very many ls1 f-body 1/4 mile times out there at all. If you have a vette or a gto you can post those times also! Please list all your mods with the car and how much boost you're running. Thanks
Old 12-10-2012, 05:53 AM
Packy's Avatar
Times in my signature along with mods.
Old 12-10-2012, 07:13 AM
dschmittie1's Avatar
back when mine was Procharged with a M6 on a forged stock cube motor making 676rwhp I went 10.3@138mph with some clutch issues
Old 12-10-2012, 08:24 AM
brians91formula's Avatar
MikeP2002 went 9's with a 383 and a D1SC in his vette. It now has an F1A so he might be faster.
KP went 9's with a D1SC as well.
As long as the car is setup properly, a procharged car can move out.
Old 12-10-2012, 12:47 PM
sweet99ss's Avatar
Your times are most interesting to me.. Trapping 129 with only 8psi on a p1sc? That's pretty impressive. Do you know how much you gained with the p1sc or did you do mods while you had the procharger on the car?
Old 12-10-2012, 05:23 PM
I8UR4RD's Avatar
347ci ---- f1-a-----formula-------8.98 at 150+mph. 3400lbs. badass car, but not mine.
http://www.streetfire.net/video/8-se...007_710762.htm
Old 12-10-2012, 08:44 PM
Packy's Avatar
Thanks, but it is a really simple set-up. I have an LS1 with forged pistons/rods, small blower cam, stock 241's with dual valve springs/hardened pushrods and an LS6 intake fed by P1SC-1 (8psi) with an FMIC and Alky control Meth injection. I don't really know what it used to run because I ran a totally different combo with the stock LS1 until 2003 when it broke a ringland. After that I had forged pistons and rods done with a blower cam also. I couldn't afford heads back then so I just used a set of take-off 2002 heads from a buddy that was getting some aftermarket ported heads for his car. The car was a six speed until 2007 when I put the TH-400 in it. With the six speed it ran a best of 10.98 @127 and with the TH-400 the current time in my signature. I am in need of switching the gears out though because with my converter I am running out of gear around the 1000' mark these days. This motor is running better and better each year though! My goal is to run a 9 sec pass with the P1SC-1.
http://youtu.be/ZiD-KB4WNXw
Just for a bit of reference I ran 107mph in the 1/8th so you can see how much I was losing on the top end due to my gears.
http://youtu.be/vqqNbDoY2vE
Old 12-11-2012, 11:47 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
KP ran a 9.13 at 149.50 mph in his '98 Trans-Am with a D-1SC. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 12-11-2012, 11:53 AM
LS1Tech Sponsor
http://www.planetlsx.com/vehicles/19..._2010_List/147
Check out this now outdated list. My Camaro driving through the converter was #94.
KP was #77. Bob
__________________
Old 01-06-2013, 03:30 AM
sweet99ss's Avatar
Forgot about this thread! Anybody else have 1/4 mile times they want to share with procharger?
Old 01-06-2013, 05:54 AM
StreetSilverado's Avatar
I'm hoping to soon. Have been a 6.10 in the 1/8th on low boost....so it should have went 9.60ish. Full weight 02 Camaro. 410CI, TH400, F1A (10lbs), 3,750lbs 10lbs so far.
Old 01-06-2013, 08:18 AM
kvelasco1's Avatar
I went 9.77 at 144mph with a d1sc 15 pounds on stock ls1 short block with a cam
Old 01-06-2013, 10:57 AM
I8UR4RD's Avatar
+badss+ Went 9.95 @ 140mph.
6.4L with F1-A
317's
Iron block
4l80e
93 Octane w/meth
His 60 was 1.51
He is also tapping the limiter
weight is around 3800+ lbs
and this is only the 4th pass made so far.
Old 01-06-2013, 11:00 AM
eb02z06's Avatar
Here's a few Vette's for you
First one is Ricky's, just a forged 347, Novi 2200, stock heads, 6 speed.
Would of been faster but his blower pipe kept blowing off.
My buddy Shanes, 427, YSi, RPM A4 conversion.
My own car, 402, YSi, RPM A4 conversion
Old 01-06-2013, 12:55 PM
LS1RedZ's Avatar
I've ran 10.50s. 370 with d1sc, 6 speed at 3700+ lbs. never really got it dialed in. Now I've got a f1A and th400. Can't wait to get it back out with the new motor. Car was making 700rwhp @ 12ish psi.
Old 01-06-2013, 06:36 PM
sweet99ss's Avatar
Damn those are some serious setups! Keepem coming! Guys with less serious don't be scared to post up. I'm just looking to see how these procharged cars are running with all kinds of boost
Old 01-06-2013, 06:42 PM
ChrisUlrich's Avatar
trapping 138 with 676whp?! Siiiiiick!!
Do Prochargers typically trap more than turbo setups with similar power numbers? All things being equal?
Old 01-07-2013, 08:58 AM
ATVracr's Avatar
We went 7.75@184mph ... With an F1r
Old 01-09-2013, 08:52 PM
sweet99ss's Avatar
Keepem coming!
Old 01-10-2013, 08:12 AM
Ballzee's Avatar
i ran 11.80 @ 119...1.7 60ft------- 6-7 psi. hot weather and 3800#. ls6 intake, stock heads,stock block. bunch of mods. 3.55 gear. need colder weather and a pulley...
Quick Reply: ~Procharged ls1 f-body 1/4 mile times~
