Stock 4.8 & t76 What cam???
Old 12-10-2012, 09:38 AM
TURBO10's Avatar
Default Stock 4.8 & t76 What cam???
I have a 2000 Silverado and im putting a 4.8 in it with a T76 with a .81 AR I need to know what cam. I have been told by friends to get a 01-02 Z06 - LS6 Cam and run the LS6 springs as well... I do not have the converter already so Dur is Open.. I have to change the carrier in the rear to a locker as well so gear is an option to .. I was going to run a 3.42 ... Trans is going to be a Built 4l60e.. We have a guy that is getting 700-800 RWHP on his in cars heavier than 3800#.. This will be a daily driver and im looking for around 600-650 at the tires.. This is a project that i picked up ...
Old 12-10-2012, 09:43 AM
turbocamaro125's Avatar
I have a 4.8 and t6 s472 with a ls9 cam and works very well. ls9 cam is like 94 bucks
Old 12-10-2012, 09:59 AM
TURBO10's Avatar
With early Cathedral heads??.. I know it works good with a L92 Head???
Old 12-10-2012, 12:25 PM
LT1RAY's Avatar
Yes with cathedral heads. Check out Tick Performance and the stage 1 turbo cam.
Old 12-10-2012, 12:56 PM
yes with 243/799 heads works great at 22psi
denmah uses them on pretty much all his builds
Old 12-10-2012, 01:56 PM
TURBO10's Avatar
I have 862 casting heads... IDK anything about them... Oh!! I have to keep the 3bolt im using a rear cam sensor..
Old 12-10-2012, 02:54 PM
ls9 cam is 3 bolt
sorry just saw the rear cam sensor
Old 12-10-2012, 04:11 PM
TURBO10's Avatar
Originally Posted by turbocamaro125
ls9 cam is 3 bolt
I guess thats why everybody tells me 01-02 Z06-LS6 Camshaft... I would love the LS9 profile with a rear sensor ring.. Are the 862 Heads any good?
Old 12-10-2012, 10:41 PM
TURBO10's Avatar
Is the TU1 a rear cam sensor cam and 3 bolt..... Or does anyone have a used LS6 01-02 cam
Old 12-11-2012, 12:15 AM
831jd's Avatar
The tu1 cam is a rear cam sensor. And 3 bolt and the 02-04 ls6 cam I bigger and better then a 2001 ls6 cam do u already have the turbo if so what brand?
Old 12-11-2012, 12:17 AM
831jd's Avatar
I would run the ebay gt45 turbo better. Ppl have gone low 9s with it and with a 4.8
Old 12-11-2012, 12:44 AM
itsslow98's Avatar
LS6 is a good cam for your setup. Dont forget the 04-05 cts-v also had the same cam as the vettes should you come across someone selling theirs.
Old 12-11-2012, 12:58 AM
TURBO10's Avatar
Its a CXracing T76 w/ .81 ar .. Its the same turbo that was used on the Big Bang Theory in the HotRod Article .. Only looking at around 17-20 psi AtoA intercooler.. Pass side log with a Truck mani on the D/S
Quick Reply: Stock 4.8 & t76 What cam???
