TC78 BMW build
Old 12-15-2012, 07:19 PM
357i's Avatar
Default TC78 BMW build
After wrecking my supercharged LS1 BMW 325i, I decided to move up to a 5 series. The downside is the car is around 600 lbs heavier... With more weight, comes the need of more power.
The old homemade setup using an Eaton m112 off of a Ford Lightning.
The new car
The engine in.
Then this stuff came in
The setup will be
Turbonetics TC78
All stainless hot side
Homemade manifolds to keep a/c
PTE 46mm wastegate
Turbo placement
Manifolds
Schedule 10 304 stainless. 1.5" and 2" OD
Pulled the motor today after marking the oil pan to notch it some so it will clear the steering rack a little more.
Manifolds an motor, tacking 2.25" v bands on.
Mocking up the cross over pipe
2.25" stainless 16 gauge pipe
And that's where I left off this evening.
I have seen some people use a flex joint in cross overs. What do you guys think?
Old 12-15-2012, 07:26 PM
Jimbo1367's Avatar
looks great. Awsome looking car. year????
Old 12-15-2012, 07:29 PM
357i's Avatar
It's a 99 528i
Old 12-15-2012, 07:35 PM
LS1NOVA's Avatar
Great job with the pipe!
Old 12-15-2012, 07:57 PM
JJMclure's Avatar
Very nice! Are you changing the rear axle?
Old 12-15-2012, 08:01 PM
Blown02Camaro's Avatar
This is going to turn out to be an insane car when its done.. Im watching this build
Old 12-24-2012, 04:02 PM
burbalanche's Avatar
putting a flex in the crossover will make it easier when u go to put it back together after welding.just make sure to use a good flex section.
Old 12-24-2012, 06:19 PM
Blackpanther99's Avatar
This is gonna be a great build.
Old 12-24-2012, 06:29 PM
Tjabo's Avatar
An unbelievably clean build so far!
Old 12-25-2012, 02:49 PM
Benwb's Avatar
where did you order your manifold tubing?
Old 12-30-2012, 07:30 PM
357i's Avatar
acestainless
Old 01-02-2013, 07:41 PM
Kory 88Iroc Lt1's Avatar
sweet build. Nice fab work. in for results.
Kory
Old 02-15-2013, 12:08 PM
357i's Avatar
Had to modify the drivers side motor mount to allow the downpipe to go through it.
Wastegate placement
New crossover pipe
Some new scrap aluminum
Old 02-15-2013, 02:05 PM
Oh4GTO's Avatar
Your serpentine belt is going to hate you. Cool motor mount idea though.
Old 02-17-2013, 05:56 PM
357i's Avatar
Here is the final finish on the manifolds. I'm not a fan of shiny things under the hood so I decided to sand blast them then go over them by hand with a scotch-brite pad.
One last full mock up to check some clearances.
Next on my list was to make a little more room for the 4" intake. I cut the "frame rail" and notched it, then welded in a new section.
Also made some brackets for the aluminum radiator the utilizes the stock radiator mounts. More on that later.
Old 02-17-2013, 06:05 PM
allout06's Avatar
hopefully ur not running an open wastegate.. thats gonna make the engine bay messy. other than that awesome job man.
Old 02-17-2013, 06:13 PM
357i's Avatar
Nope, will be riunnng a 2" pipe back into the exhaust. Still need to make a notch in the inner fender to make some room for that.
Old 02-17-2013, 06:23 PM
allout06's Avatar
good good. i looked at the clearance and thought "That is gonna make a mess if he doesnt recirculate that lol..."
Old 02-17-2013, 06:59 PM
JAX04's Avatar
Wow, nice change of pace. I remember when you did the supercharger build. I like this alot. Good work. Thats def an interesting and unique way to do the turbo. Kick *** for doing something different.
Old 02-23-2013, 07:45 PM
357i's Avatar
Added a -4 turbo feed fitting to the oil cooler adapter
Here is the notch I had to put in the oil pan. The welds aren't great due to the aluminum being cast and oil saturated...but it's sealed fo sho.
Here is the pan on, turbo feed and drain in place
Lastly I started wiring the motor up. I plan to fire the engine very soon!
Quick Reply: TC78 BMW build
