Any online resources for learning to build a turbo kit?
Old 01-24-2013, 04:31 PM
SPRAYED 01's Avatar
Default Any online resources for learning to build a turbo kit?
Im very interested in starting to build my own custom exhaust and turbo kits for my own projects and for fun, not a business.
My background is auto mechanics,10 years at Mercedes and now i work on heavy duty diesel. I built my own garage with a lift and a complete set of tools. Im very well versed in cars.
My lack of knowledge is in custom fabrication. I took a welding course about 12 years ago. Id like to buy both mig and tig, along with a nice table saw to cut the pipes.
Im looking for anything i can learn from primarily in cutting specific angles needed to make a custom exhaust or cold side. Any videos or books that some one knows of?
Thanks
Alex
Old 01-24-2013, 05:55 PM
Cronic_Moronic's Avatar
Youtube and google are great.
Old 01-24-2013, 06:01 PM
Cam72aro's Avatar
I did a lot of learning from this website. I looked at many builds to get ideas.
Old 01-24-2013, 06:52 PM
k_cash1432's Avatar
Your going to be dropping allot of coin into welding equipment just to do this. espically if you buy a decent tig but plan on dropping 2k to get setup with both welders by the time you buy a bottle of C25 and argon for the tig... with that kindo of coin you can buy the hurron speed kit in the classified and have money left over for the beer to do the install...
Old 01-24-2013, 07:04 PM
code4's Avatar
Thanks
Alex
I don't know of any table saw I would use to cut metal. I use a chop saw & a mig. Airflow is pretty basic, I learned by experience not on some internet site or book.
Old 01-24-2013, 07:22 PM
Cam72aro's Avatar
Like mentioned, a lot of skills come from experience. I learned how to tig and mig when I was around 12, now 30. My dad taught me what I know. I built my turbo kit using a mig and recently picked up a tig. I have a hobart handler 140 and a miller dial arc hf 250. The tig was $800 and the mig was around $550. A good chop saw like said and you are building away. I have done some chassis work and roll cages a few years back. Find some small little projects that you are comfortable with and go up from there. Build a bbq pit or something so you can get a feel for it.
Old 01-24-2013, 07:31 PM
LS1NOVA's Avatar
Id recommend a bandsaw over a chop saw and to just get going with a Mig until you have done a few projects. Stainless tubing and Tig is much more tedious and time consuming. It also required a second argon regulator and tank to backpurge. Start simple and move up.
The tools I use making a turbo kit:
Milwaukee portaband on a chop saw style base.
Miller 211 Mig, but any 125-140amp gas style Mig is fine
Miller Diversion 165 Tig if its stainless
Air angle gringer with a 36 grit grinding wheel for pipe fitment after cutting and removing aluminized coating prior to welding
Air die grinder with a carbide bit for cleaning out minor cutting flashing inside the pipes
Drill and stepbit for 02 holes etc
Hammer and a vise for shaping tubing to fit in square holes
Old 01-24-2013, 08:46 PM
tiznodd's Avatar
LS1NOVA's list of tools pretty much covers it! I made my own turbo system and had basically no experience going into it. I had never touched a tig welder before I started my project. I bought a Hobart EZ-Tig, which is the same as the Miller Diversion. Look at lots of photos to get an idea of what you want to do and watch lots of youtube videos for welding help. As long as you have some mechanical aptitude, you should be fine. Be sure to take your time, and when in doubt, go back to the all-knowing internet for guidance. Good luck!
Old 01-24-2013, 08:50 PM
SPRAYED 01's Avatar
Kcash, let me clarify. I'm not looking to save money over buying a kit. My car has a turbo on it and is fully built. Im looking to further my hobby. I built a new garage and i do alot of work in there. For example i just put a larger 88mm turbo on my ta. Id like to build my own 4 inch dp and connect to the rest of my exhaust. Id like to learn to do this my self.
Thanks alot for listing all the choices of tools, that helps. I was even just looking for a video of anyone building exhaust, making cuts, measuring angles,tips of the trade. Anything would help.
Alex
Old 01-25-2013, 05:47 AM
LS1NOVA's Avatar
Just keep the cuts 90 degrees to the pipe and you'll be fine. There are some instances where you may need to pie cut but for the most part cutting 90 to the pipe keep the diameter consistent and gaps tight. Its also easier to use 45's and 90's to make the bends and do the cutting and welding on a straight section. It costs more to do it that way but its easier welding them for a newb due to the pipe thickness being consistent thickness.
Areas with vbands you need to be carefull too. Stick the pipe barely through one flange so it locates the vband assembly for easier assembly. Do all welding on vbands and wastegate flanges with the flange bolted together or wastegate attached. It will warp most times if you dont.
Old 01-25-2013, 06:48 AM
Sarg's Avatar
Also check out weldingtipsandtricks.com for tig help and instruction. Lots of good information there! It has helped me a lot to pick it up. I use a cheap chop saw and then just gring out any slag from the inside before welding.
If you are doing tig, clean, clean clean the metal before welding. Never use brake cleaner or anything like that on ANYTHING before welding it. Water and acetone only. I about killed myself (literally) by welding on something that apparently got sprayed down with brake cleaner. It turns into a very poisonous gas when welded!
I use 16g stainless mandrel bends and sometimes sch 10 stainless pipe to make the exhaust. Works pretty well, but if you have to cut the sch 10 you better have a very good saw. It is thick and tough!
Old 01-25-2013, 07:02 AM
PROLSXSS's Avatar
best way to learn is to get the gear and do it.... practice heaps and make mistakes. It might sound rude but it works
Old 01-25-2013, 07:03 AM
stevieturbo's Avatar
I wouldnt worry about using TIG...just MIG it all. It's faster , cheaper and no need to backpurge.
IMO TIG'ing offers no real benefit at all, other than looking pretty
As for cutting pipes, grinder is fine. Stick a hose clamp around the pipe, whether t-bolt or other, but a wide band can be better. And use this as a cutting guide. If it's a snug fit around the metal pipe, you can ensure a good straight even cut around it's diameter, especially on bends.
Old 01-25-2013, 07:04 AM
SMOKNSS's Avatar
These are two good answers. Any fabricating me and/or my buddies do is trial and error based on what we see. There are many forums with great build threads and information on what people have done to give you good ideas.
Check the stickies in the forced induction section, there are some stickies on building turbo kits and stuff of that nature.
Good luck.
Old 01-25-2013, 08:31 AM
Sarg's Avatar
If you work with stainless, mig or tig, you need to purge if it is pre turbo. If you do not it leaves weak little chunks of crystalized looking metal on the inside that can break off and take out the turbo. If it is mild or aluminized you do not have to purge with mig or tig. Tri-mix gas for migging stainless is kinda expensive and hard to get in small bottles. Argon for tig is pretty cheap but you will use more of it with tig.
One thing I do agree with is just get the materials and practice. No replacement for hood time. But videos do help to show what you are supposed to do. I got a $550 brand new china tig that has served me well so far. The only downside is it is dc only, so n aluminum
Old 01-25-2013, 09:24 AM
Twin turbo c5's Avatar
Here is the best. You got some nice kits being built on here and some junky ones like what I build. I learned from just doing and made mistakes but its not rocket science.
Old 01-25-2013, 09:44 AM
Sarg's Avatar
One other thing I thought about....make sure any two tubes or pipes you are welding together fit up almost perfect with almost zero gap and your experience will be much better! A good tubing notcher is very helpful for things like merges and wastegate tubes.
Old 01-25-2013, 11:35 AM
V-seriesTech's Avatar
Thats what I am saying.
Old 01-25-2013, 08:09 PM
Cam72aro's Avatar
Thanks. I was went from a procharger to turbo because of seeing what others had done. Mig welding is easier and will get pretty much everything you need to do done. Tig is just another tool that expands your shop. Most of the cutting and fitting process is eyeballing and trimming with a little measuring. Practice practice and you will pick it up.
Old 01-25-2013, 08:42 PM
k_cash1432's Avatar
My apologies. Yes trial and error your best friend, I have put together 3 turbo kits for fbodys all tigged with good results. Take your time and measure twice cut once and gring to make perfect. the more time you take to make it perfect the better it will be when you go to put if all together for a final time.
Quick Reply: Any online resources for learning to build a turbo kit?
