View Poll Results: Are CNC ported heads worth the expense on most turbo 5.3 builds??
Voters: 27. You may not vote on this poll
For a semi-budget turbo 5.3 build are (CNC) ported heads worth the expense??
What I mean by "semi-budget" is that I am willing to buy a junkyard high mile L33 but instead of just flopping it into my car I would have it rebuilt with a machined crank, LS3 rods, fresh bearings and rings, fully balanced rotating assembly and ARP fasteners everywhere.
I know this type of question have been asked on other threads but the answers seems to always come back kind of fuzzy.
The power goal is 600 to 700 RWHP in a 1995 Impala SS/Caprice daily driver street car.
Bottomline: Are ported stock 799/243 heads or even aftermarket TFS's or AFR's heads worth the expense on such a build or shall just forget about it and turn up the boost an extra 1 or 2 psi????
CNC ported heads are not expensive, so it's hard to say that they arent worth it. Especially as they'll come with better valves and springs already.
They will help power/torque both on and off boost. So a lot will depend on actual usage too.
The hp level you are wanting should be easy to reach with stock heads, check out the thread about the Fairmount. He made the numbers that you are after, and I think he even had two different casting heads.
The poll posted is some what vague and with the goals you stated it does not completely apply.
I would find a good buy on a useable set of 243/799 and go.
You know there is a school of thought that says the stuff that makes a good N/A motor like good if not great flowing heads, intake and exhaust does not apply to FI motor esp. turbo motors.
With a turbo, the air flow works entirely different than when na. A na engine relies on the cylinder to draw air in, with a turbo there is always constant pressure blowing in.
That said, NA or turbo, any means to increase air in and out is never a bad thing. To directly answer the OP's question. Yes you can reach your goal with bone stock heads, many have done it. I am currently building a 5.3, my goal is around 1000hp and I am using stock heads with stock valves that I ported myself.
Two good points Stevie!! Thanx but you should have voted for the first on the poll.
For a turbo setup, yes you can ram more power down their throats, but even a simple clean up, better valves and springs is a very cost effective improvement.
The key is value for money, and most of the ported head offerings are very good value in my eyes. So there really are no negatives.
You could make all the power in the world with stock ports one way or another. It doesnt always mean it is the best approach to doing so.
Just boost it and have fun. lots of us are making power on stock untouched heads. I just made 670hp on a set of stock untouched ls1 heads with 14 pounds of boost. Save the time and money and go have fun and do some burnouts.
I'm in a similar situation, im in the process of a pt88 forged 408 build and cant decide if i should just spend a $100 to clean up my tfs 215's or a $1,000 to completely port them and larger valve's? from what iv just read it seems like i could just add 1psi and it would be the same
Thanks for the reply man, the guy that does my heads made it sound like it would be a world of difference like 100hp on 15psi, but he is one hell of a sales man...
i think there should be a rule : dont put expensive heads on boosted junkyard engines:
1. if your engine lets go, you more than likely just trashed your expensive heads
2. if you spend the money building the bottom end, you can make 400-600 more hp by turning up the boost- or you could put heads on instead and only make 100 more hp.
i vote that this should be an ls1tech forced induction section, plain old vanilla common sense rule.
Good god at the advice given in here...
Proper head sizing still matters with a turbo...
215cc tfs on a 408? Probably gonna choke out by 6000 rpm.
The laws of physics still apply to a turbo...
800 hp.. with 862's... with 12 psi... on a 6 liter???? Cmon man....
stock ls1 heads on a 408 made 550 peaking at 6200. at 15 psi on e85 , thats 1100hp.
procomp heads with a 219 cc runner did 629. thats 1258 at 15 psi john.
http://www.hotrod.com/techarticles/e...t/viewall.html
please advise, what 3000lbs, with an mph of 117.4 in the eighth, is making for hp, then what if i showed you the datalog that shows full throttle for only the last 2.0 secs of the pass? you tell me how much power that is showing. i dont do shoulda coulda wouldas. thats why i said 800. the timeslip can back that up. the engine is making 900+ on 12 psi, with factory stock 862 heads that i bought for $100.
hint
http://www.rehermorrison.com/PdfFile...eriesHP_ET.pdf
FURTHERMORE,
what is so special about a 6.0 on methanol making 800hp on 12 psi? if my engine were making only 800hp on 12 psi, being a 1.81 pressure ratio, that would mean my engine is only making 440 NA at the flywheel. LOL, and i would have every right to be pissed, when ive seen 6.0s make that to the wheels.
only 440hp with methanol, a cam and a vic jr intake? get outta here with that bs.
