317's how much to lift
Old 02-02-2013, 04:52 AM
js2fst's Avatar
Default 317's how much to lift
I have ported 317's ls9 headgaskets how boost of hp can I do is take
Old 02-02-2013, 04:54 AM
js2fst's Avatar
Also studs and it is a lq4 iron bloc 408
Old 02-02-2013, 07:36 AM
Wicked69's Avatar
Probably will take more than you need. 20lbs shouldn't be an issue with studs and LS9 gaskets.
Old 02-02-2013, 12:46 PM
js2fst's Avatar
What else to prevent it
Old 02-02-2013, 12:49 PM
typhoon1015's Avatar
a proper tune and good fuel it will live decently depending on goals
and your first post is a bit confusing,
"how boost of hp can I do is take" lol
Old 02-02-2013, 12:59 PM
MillsMotorvation's Avatar
With studs, any psi, stock 6.0 bottom end 10psi.
Old 02-02-2013, 03:01 PM
allout06's Avatar
ill reiterate what AES told me. from their testing, they see the 6.0L iron blocks start to push water around the 22.5psi mark on a 4-bolt head, standard head stud. They said the heads lift a little, but from what theyve seen, its more so the cylinder walls themselves expanding about the width of a human hair, and causes water to enter the cylinder. take it for what its worth.
Old 02-02-2013, 04:37 PM
Old Geezer's Avatar
Talking Probably...
too many hits on the bong, while typing!
Old 02-02-2013, 09:50 PM
9 Second Truck Club
stock48's Avatar
Stock bottom end Lq4 with 317 heads with ls9's, and std ARP studs and S480 Maxed out at 25 psi no water pushed. Can't say how long it will hold with 25psi but been many pulls with 20~23 psi. Different blocks and heads are thicker than others so hard to put an exact number on it but if things are right you should be able to run 20~23 psi with no problems. The 2004 up blocks with short head bolt hold better than the early long bolt blocks. With early block, and std MLS(pre ls9) gaskets I started to push water past 20 psi. Also deck prep/surface has a lot to do with things, those scotchbrite discs many people use destroy decks.
Quick Reply: 317's how much to lift
