Any 5.3 F1 pro charged combos out there?
I've been thinking about a f1 5.3 combo, but I can't find any results from current combos. Anybody have a setup like this running?
I have a lq4 6.0 f1a
Stock bottom end lq4
afr205 heads with ls9 head gaskets
Brute speed blower cam
edelbrock victor jr intake
procharger f1a 10psi with aster bracket 5inch pulley
accufab 4150 throttle body
Extreme Velocity carb hat
procahrger blow off valve
cxracing intercooler
qtp headers
127lbs injectors
th400 trans circle d converter
9inch rear 3.50 gears
pump gas no meth
650rwhp 564rwtq
qtp headers
127lbs injectors
pump gas no meth
650rwhp 564rwtq
qtp headers
127lbs injectors
pump gas no meth
650rwhp 564rwtq
qtp headers
127lbs injectors
pump gas no meth
650rwhp 564rwtq
Too many people get pressured into buying big cubic inch engines. Sometimes it just isn't necessary. If people didn't think out of the box every ls1 would still be running ported 853/241's with a MTI letter cam, or a TR224 cam.
There is a picture of the dyno sheet on the video
http://www.youtube.com/watch?feature...&v=8SVPLet904s
Im surprised the turbo on the same boost didnt pick up substantial mph, unless you were much more conservative tuning it this time around
Bone stock 99 5.3 with 150k on it and swapped in new LS6 springs. 72lb injectors. Torqstorm supercharger pushing 9psi thus far at 4500rpms. Should make 11-12psi. According to the datalogs and fuel consumption I'm in the 500hp range at only 9psi. and it should make 2psi more in anothe 1k rpms.
The torqstorm is a smaller blower but makes boost very low like 1700rpms. The F1A should make more boost and more power up high.
I'm running 17-18* timing but have a speed daddy FMIC and meth injection pre SC and after intercooler shooting wiper fluid.
I'd love to try F series. Maybe this winter when a buddy goes from F1a-94 to twin turbos.
5.3, 317's, tick blower cam, D1sc 7.25"/3" pullies I was making 12psi at about 4000rpm but was getting belt slip after that making 500hp at 4k and only managed 530whp up top with the slip. Pulley changes and I'll be over 600whp
