denmah's commonly bought turbo car items (update 7-11-16)
https://amzn.com/w/F4LXEABS2V59
in an effort to keep up a better frequently bought sloppy items list, i made a public amazon shopping list, aptly named the sloppy mechanics frequent buy list, haha
its harder to link this stuff since items go out of stock and ill try to keep this updated with suggestions and parts, obviously this is stuff only available on amazon, but its where i get half my parts the rest are from Viren Singh or a manufacturer direct.
let me know if you think this is a good idea, and if you have amazon parts links you would like me to add or you think people will find helpful, ill try to update it as much as i can with known reliable parts, not much in there now, going to try to add more as i remember them and or purchase/link peopl
i get questions alot, am i allowed to post up a list of common turbo car stuff i buy and use and links to them or is that some kinda sponsor trouble?
i plan to update the thread and link people to it in my sig or something, ill wait till someone says its ok before i post it all in here haha
this is the 4l80e transgo HD2 kit we install in 4l80e's
http://www.summitracing.com/parts/trg-4l80e-hd2
this is the radiator that i put in fox body cars, we also sometimes make them dual pass and move the neck to all on the passenger side to make hooking up the water hoses easier.
http://www.summitracing.com/parts/sum-380431
intercooler and coupler kits
you can get from VS racing and ebay for like
199 dollars for a 30x12x3 wich will handle lots of power, comes with piping, clamps, couplers, works great.
you can get 4 inch intercooler and 3 inch piping etc they are easy to find if you need links let us know we can dig em up but ebay is littered with them.
Denmah Sloppy Special universal turbo kit parts from VSracing (package deal)
yes its true, i have bought the same components so many times from VSracing that he offers it as a package, with some upgrades and other things available.
Denmah - sloppy mechanics special - universal turbo parts package
Megasquirt ECU and sensors
EFI source 3 bar map and pigtail
EFI Source
320 South Franklin Street
Boyertown, PA 19512
Tel: (610) 473-2089
Fax: (610) 473-2086
ebay links are down but please email or call them for products
he is also modding the Microsquirt at request so you dont have to do the ecu mods if you are going to run a lsx engine
http://cgi.ebay.com/ws/eBayISAPI.dll...m=121041299443
microsquirt v3 with 8ft harness from efi source
http://www.ebay.com/itm/Megasquirt-M...item19d4e53cce
AEM UEGO wideband O2 sensor
http://www.amazon.com/AEM-30-4100-UE...=5336075431-20
EFI Source
Boyertown, PA 19512
Tel: (610) 473-2089
Fax: (610) 473-2086
valvesprings
pac 1218 springs good for .600 lift max from SDparts
https://sdparts.com/details/pac-racing/pac1218
80 dollar head studs and gaskets
Recently i had trouble getting the right studs from KMJ's website, i think the listing is broken or moved, i couldnt find it and i bought them from alpermotorsports on ebay instead.
ill email them about fixing it or giving the correct link, or just look up alpermotorsports on ebay instead.
4.8-5.3,5.7 MLS stock head gaskets (cant use on 6.0)
http://www.summitracing.com/parts/nal-12498544
3rd generation KMJ studs for LSX motors 3 size studs
http://www.kmjent.com/cart/sbc-chevy....7l-97-03.html
4th gen 04-08 head stud kit for lsx motors
http://www.kmjent.com/cart/sbc-chevy....7l-04-08.html
boost controllers...
NXS manual boost controller
http://www.ebay.com/itm/NXS-MANUAL-B...b9eeae&vxp=mtr
AEM tru boost electronic boost controller
http://www.amazon.com/AEM-30-4350-Tr...ords=tru+boost
Radiators
supra_speed
http://www.ebay.com/itm/110897372073...84.m1423.l2649
sarg says he has used this dual pass radiator/ same side in out with success in his fox
http://www.ebay.com/itm/400095318155...84.m1423.l2649
supra_speed
Oil feed and drain stuff
T4 -10 drain fitting i usually buy for t4s
http://www.amazon.com/Fitting-Turbon...t4+feed+flange
T4 -4 feed with restrictor built in
http://www.amazon.com/Turbo-Feed-Ada...t4+feed+flange
turbo werx scavenge pump for remote or rear mounted turbos
http://www.ebay.com/itm/TurboWerx-Ba...8307d6&vxp=mtr
1/4 inch thread oil feed for the oil pan, billet 20 dollar piece
http://www.ebay.com/itm/271140973859...84.m1497.l2649
i used this on my truck since it had the cooler and i didnt have an extra oil pan thing to drill and use
intake and fuel injector stuff
set of 8, 80lb siemens deka injectors for 340 shipped
http://www.ebay.com/itm/Siemens-Deka...ae65ae&vxp=mtr
cooling mist base meth injection kit on ebay, cheaper than their website
http://www.ebay.com/itm/110679586274...84.m1497.l2649
the 3.75 (ls1/truck throttle body sized 90 coupler to 3 inch IC piping )
3" to 3.75" 90 Degree Reducer Silicone Coupler Black/RD
http://www.ebay.com/itm/3-to-3-75-90...4d8ba4&vxp=mtr
this is the 2.5 inch to 3.75 inch (truck/ls1 throttle body 90 i have also used
http://www.ebay.com/itm/2-5-TO-3-75-...597303&vxp=mtr
Originally Posted by SleeperZzZ28
hope you dont mind, heres a few more
modular turbo's oil feed block
http://vtsql.gkvbf.servertrust.com/L...ck-p/cbr02.htm
alt relocation bracket
http://vtsql.gkvbf.servertrust.com/C...it-p/cbr01.htm
amazon has eboost 2 for $479
twin in tank pumps
http://www.airpowersystems.com/fbody...sgmf-fss01.htm
http://www.lonniesperformance.com/fbodyfuelsystems.htm
DIY twin pumps on the quick and cheap
twin in tank pumps
ill add to it
ebay catch can that i have
http://www.ebay.com/itm/BLEMISHED-Ba...vxp=mtr&_uhb=1
blow off valve
http://www.ebay.com/itm/EMUSA-50mm-B...vxp=mtr&_uhb=1
WASTEGATE
http://www.ebay.com/itm/EMUSA-38mm-W...vxp=mtr&_uhb=1
blow off valve
WASTEGATE
I wanna help some too...
dual gss340 and 341 KIT with Yfitting etc. 219 bucks! not bad
http://www.sho-mespeed.com/index.php...ry_pathway=629
Good post!
Not my post but ill add that i and several others have had great luck the the intercoolers and piping from CXracing on ebay... great budget stuff!
I usually get the universal kit with the cheap a$$ purple BOV, I personally havent had one fail yet....
NXS manual boost controller or i buy a AEM tru boost
i actually used CXracing turbo kit on my d series honda that came with everything and it was great.
for wastgates i like the ones viren sells. or just like this one
http://www.ebay.com/itm/300847355425...84.m1497.l2649
these are 13mm header bolts i recently swapped in since my truck had 4 broken bolts and i dont like the 10mm bolts
http://www.ebay.com/itm/140738027105...84.m1497.l2649
they work great also
I cant wait to put a micro V3 on my car!! Thanks for taking the time to make the how to video too!!
