Root/Twin Screw - Supercharge Options
Bravo to all those Turbo / Procharged Cars, but I dont want It. <(Period)
I have researched 98-02 F-Body Root or Twin Screw Kits.....
Maggie - Magnuson, Whipplie , Lyshyom Vortech ... you name it !!
All the info is stuck between 2008 - 2010 on Superchargers & the only Hot builds in 2013 for LS Supercharged Builds are for GTO's / Holden's ....
Is there any SuperCharger option that replaces the Intake for any
LS1,2,3,4,5,6,7,9,A what ever, that could fit under 98-02 Hood ??
Extreme Modifications Accepted !!
UNDER PRESSURE MOD
Anything will fit with "Extreme Modifications" Hell, you could fit a big block with an 8-71 blower on it if you really wanted to.
The reason you don't see many/any positive displacement build for 4th gens is the height restriction for the manifold. To even get the 112 to fit, you had to cut the cowl, drop the motor, and then it maxed out at like 500rwhp, and still cost you upwards of $7000.
This has been done about a dozen times on here, but people started to see the light that the money invested wasn't worth the outcome.
So if you want to fit a big Kenne Bell or Whipple, they make LS sandrail kits, so then it's just a case of hacking off your windsheild wipers and cowl, then dropping your motor and then figuring out the accesory layout.
Anything can be done with enough money.
Be prepared to cut out your cowl, wipers etc... There is not a direct bolt in everything stays kit out there for the 4th gen fbody. People have tried and failed. But for extreme modifications, you either have to do it yourself or have a shop do it. Heck, anything can be done just what The Alchemist said! How much money do you have is the question...
Just like both of the guys above said. If you have the $ and don't mine hacking up your car to get it done you can put about anything under the hood. People have put whipple superchargers on 4th gens, but you have to cut the cowl, remove the wippers, and lower the engine a bit.... I looked at putting a twin screw on my car for ever and finally decided it just wasn't worth all the $ and hacking of my car. Now I have parted together a complete d1sc procharger kit that is easy to install and I have $3k total into it.
Thanks guys for the $$$ Prep talk,
Lets put usefull info on this thread. Honestly I don't think its that IMPOSSIBLE !!
but with the lack of Information .. every step will be a hassle ....
So this thread is to absor as mush usefull information gathered around whether from mistakes or success stories from around the members of this forum.
1. Do you have $8k plus to spend?
2. Do you have the skills to tackle a project with a lot of custom work?
3. Do you mind cutting your cowl, removing your wipers, and lowering the engine?
4. Are you willing to take the time, do the research and piece the parts together while your car sits torn apart for a long period of time?
If yes to all the questions than you shouldn't have any problem.... All you have to do is get one of the blowers used for a GTO or w/e and start piecing together parts. Than start cutting the cowl where needed and remove the wipers for room for the blower.
Can you answer these questions?
1. Do you have $8k plus to spend? yes
2. Do you have the skills to tackle a project with a lot of custom work? maybe
3. Do you mind cutting your cowl, removing your wipers, and lowering the engine? I need a picture done to determine but yes i will cross the average bar
4. Are you willing to take the time, do the research and piece the parts together while your car sits torn apart for a long period of time? Isnt this a start ?
Now here is something to start with ... Lets bring more usefull data to the table.
Whipple dont have a kit (I Called last Week)
Couple of Other Sites Claimed they do make a kit (Pic's of 2008 Cars)
Magnuson Maggie max out at 550HP (From the forum research )...
On the Fastest Stock Bottom FI list there is a Vortech V & a Kennebell !! Figure to start asking them !!
Well its fair to say em vettes get all the goodies & f-body fab theirs on forums, nothing wrong with that but these turbo vettes are going wild ... Its like every vette is got a twin turbo installed. The goal is 10 second weekend warrior, Turbo (Moderate) , Twin Screw (out of the Box), Nitrous (Traditional).
8000$ for 500hp max is bull!!
500$ nos kit will do the trick for 500hp.
Turbo - too much pipes (emission's failure).
Desicions desicions!!
Looks like I'm going custom !! Time to call some forum sponsers.
start buy finding out how your going to lower the motor. usually mounts and K members will change this.
buy the kit
install it.
cut, and fab as you go.
there is a good reason why there is no info on these sorts of builds on 4th gens, but you can be the one to change all that.
buy the kit
install it.
UNDER PRESSURE MOD
The hood isn't the problem, it's the cowl. You can put a bigger hood on, but it doesn't change that the back 4 cylinders are under the cowl.
No big deal if you are willing to get rid of windsheild wipers. But if you're afraid of emmsions testing, then you should be concerned about not having windsheild wipers.
Probably going to get flamed for mentioning this, but have you considered a side mount positive displacment setup? Comes with its own problems but MIGHT allow for a PD/TS sucpercharger to be installed.
Also worth reading wrp's thread about his whipple GTO. Loads of great info on there and the extent he had to go to to get the whipple to work well.
Just an idea!
Chris.
Just an idea!
Chris.
Just an idea!
Chris.
Just an idea!
Chris.
