Show me where you mounted ur turbos on ur 98-02 camaros
Old 03-05-2013, 10:56 PM
Chevyboi09's Avatar
Default Show me where you mounted ur turbos on ur 98-02 camaros
I'm trying to find pictures of 98-02 Camaro turbo setups where people have mounted the turbo(s) in places other than where they'd "normally" go? If that makes sense? Anyways. I had seen a picture somewhere where the turbo was mounted in the factory grill in the passenger side. Looked pretty sweet and i was just trying to figure out HOW to mount the turbo(s) in that same spot. "(s)' because i think a twin setup with the turbos mounted in the grill would look sick. Good location tho? IDK give me your input please. I'm really just interested in pictures with turbos mounted in different locations, like the grill for instance.
Thanks
Old 03-06-2013, 09:42 AM
Reject's Avatar
just search red rocket. or check out the racing section.
Old 03-06-2013, 09:45 AM
LS1Tech Sponsor
Slowhawk's Avatar
Yup, search. There is a million pictures on this site.
Old 03-06-2013, 12:24 PM
9sectruck's Avatar
HERES mine stock 5.3 with a 239 252 624 114 cam looking to go mid 9s
Old 03-06-2013, 12:31 PM
Reject's Avatar
what intake are you going to run? WG looks to be in the way
Old 03-06-2013, 02:01 PM
9sectruck's Avatar
ls2 stock intake, the car has a 3inch cowl everything clears with alot of room to spare
just tuning on our local track, out the back door was around 142ish according to the logger at only 16psi and 14deg, just put all new front end on it and will be back up and going 2maro
Old 03-06-2013, 02:31 PM
9sectruck's Avatar
THIS WAS MOCK UP about 1inch between when it was done
Old 03-06-2013, 05:30 PM
Captain Double Post
BOBS99SS's Avatar
You should look at the post your turbo engine bay pic thread,looks of good stuff there to look at
Quick Reply: Show me where you mounted ur turbos on ur 98-02 camaros
