Lots of turbo questions!! 5.3+xxmm
Alright guys I need some advice on which way to go on a couple things.
On to the car.
2000 Camaro Z28
Motor and turbo setup
2007 lm7 5.3l iron block (9.5:1 compression
317 heads
comp 918
ls6 cam
mls head gaskets
ls7 lifters
ls2 timing chain
ls6 oil pump
underdrive pulley
comp hardened push rods
arp head and rod bolts
cxracing intercooler & piping
2 bar map sensor
60lbs injectors
RPS 50mm BOV
JGS 40mm wastegate
Drivetrain
TH400
Neil chance 4000 stall
B&M ratchet shifter w/Trans brake
Tci flexplate
Moser 9"
Full Spool
31 spline axles
9/16 studs
3.73s
Full suspension with 6point chromoly cage
I'm combining 2 different builds so I have options
And here's where you guys come in:
Intake:
I have an ls6 with a stock tb and speed inv fuel rails with 60lb injectors
Or
Ported Vic. Jr with 90 to a 95mm tb edlebrock fuel tales and 60lb injectors
I know the victor jr would look way badass but it was ported to fit 245cc heads on a 402, not a 5.3 with 817's. I also know the ls6 flows very well under boost, but i say why not the Vic jr if I could make some more hp.
Scavenge pump: what are you guys running?
Radiator: same question
The 5.3 was already run on a turbo setup and made 626hp with a 76mm huron speed turbo, what would be an ideal turbo to run?
What rear gears should I go to? 3.23 3.42? Not trying to break records, just want a badass street car.
On to the car.
2000 Camaro Z28
317 heads
comp 918
ls6 cam
mls head gaskets
ls7 lifters
ls2 timing chain
ls6 oil pump
underdrive pulley
2 bar map sensor
60lbs injectors
RPS 50mm BOV
JGS 40mm wastegate
Drivetrain
TH400
Tci flexplate
Moser 9"
Full Spool
31 spline axles
9/16 studs
3.73s
Intake:
Or
With a 4000 rpm stall and a brake I would look into jumping up to a Borg Warner t6 turbo. Anything from the s475 to the s480 would probably work well with the appropriate turbine wheel. I am trying out the On3 scavenge pump, but I know a lot of guys run the Turbowerks pump.
When it comes to turbo cars and gearing...theres more than one way to skin that cat.
In one of my customers cars.. he went quicker and faster in the 1/8 mile with 3.90 gears and a converter that slips 5% than he did with 3.55's amd a converter that slipped 12%
TU2 is a decent cam. Proven to work. Not the same approach I would take....but to each their own.
Personally Id do something with a little less overlap.
Liljohn- I only suggested the tu1 and tu2 cames because I see they're pretty popular with other turbo builds. If you have another suggestion, by all means that's why I started the thread, for input from the experts(you guys!!)
Most of my customers with 5.3's and the T-netics 7675's I have them running our LS2 Stage 1 Turbo cam or LS3 Stage 1 turbo cam depending on several factors.
LS2 Stage 1= 226/231 .605/.598 114+3
LS3 Stage 1= 226/235 .605/.610 114+2
The LS3 Stage 1 would work with a smaller 87mm turbine S400 series Borg as well.
