Big power with ls2 block???
The only thing I would worry about would be the caps "walking" around. Get them pinned and it should be a good, light motor. Fireball on here was running a stock sleeved ls2 that finally let go at somewhere north of 1500 hp..... Ended up cracking a sleeve.
My ls2 has pinned mains and is otherwise stock. Car dynoed 800rwhp on 15 psi.
LS2 block can be very strong with pinned mains and a little bit of block fill.
I think mightymouse was using an ERL aluminum block that was stock ls2 cubes
Thanks for the replies good info. That's kinda what I was afraid of as well as main cap walk on the window style blocks. Also don't want flexing cyl walls and a binding crank costing my power. Do the blocks usually break at the top of cyl like pic above?
Australian 98 octane street fuel, which is about the same as 93 octane for you guys. Was only running 7psi when I noticed the failure, but it might have started cracking months earlier when I was running 15psi. No detonation on the logs, but no doubt it had detonated at some point.
