Blow through 6.0 S480 - 1067hp
Old 03-29-2013, 10:11 PM
3pedals's Avatar
Default Blow through 6.0 S480 - 1067hp
100k mile 6.0, untouched rotating assy-strait from the wreaker
l92 heads, BW S480
Comp 227/235, .613/.621, 114+4 w/patriot extreme springs
Vic jr/ CSU750 blow through
AIS 3nozzle meth setup, comes in at 4psi
C16 fuel
Ls9 gaskets, Chinese studs
Just engine dyno'd it today
1067hp @ 6700, definitely a Good Friday
I also setup a 10 psi pump gas tuneup -727 hp
Old 03-29-2013, 10:14 PM
MYSTIC-1SC's Avatar
Very solid numbers!
Old 03-29-2013, 10:17 PM
knuts82's Avatar
Nice number's. Blow Through Carb is the way to go.
Old 03-29-2013, 10:20 PM
78buturbo's Avatar
Congrats that's damn good, is that s480 with a cast or billet wheel?
Old 03-29-2013, 10:31 PM
3pedals's Avatar
The S480 has the regular cast compressor wheel, standard cover and a 92mm turbine 1.1a/r
Old 03-29-2013, 10:34 PM
1fastxz's Avatar
very cool man
Old 03-29-2013, 10:45 PM
78buturbo's Avatar
The good ole 480
Old 03-30-2013, 12:17 AM
T/ALT1's Avatar
Awesome numbers, only 16-17psi!!! No intercooler Im guessing. Should make a killer street car with those torque #'s!
Old 03-30-2013, 12:58 AM
kpeterson's Avatar
I’ve been using your car as an example of why I have pretty much given up on gen 1 small blocks for a long time. Some people don’t believe the results of your build when I mention it. What are the non-believers gonna say now? Stellar job. Now it’s time for you to start blowing up driveline parts.
I have an LQ9 and few bits and pieces for my ’68 but it’s going to be while. Thanks for the added incentive to get to work.
Old 03-30-2013, 01:40 AM
71 chevy's Avatar
you skipped 3 digit hp and went straight for 4 digit hp.
congrats man
Old 03-30-2013, 06:11 AM
BottleFedZ346's Avatar
Very nice!
Old 03-30-2013, 06:16 AM
Camaro9969's Avatar
Wow that's impressive!
Old 03-30-2013, 07:27 AM
JRENIGAR's Avatar
Nice, how long do you think it will last at that power level?
Old 03-30-2013, 11:33 AM
3pedals's Avatar
Im not sure. The tune is fat except at the upper end of the pull, and there is NO heat mark on the plugs, way safe. this tuneup will Not be run on anything axcept c-16, and ONLY at the track with a progressive boost controller!
I made a tuneup on a 10psi wastegate spring at less timing to be able to run 91pump gas w/ water-meth, on the street
Old 03-30-2013, 11:42 AM
Prorac1's Avatar
Great results Barrett, congrats. Eric L
Old 03-30-2013, 11:48 AM
3pedals's Avatar
pics after unloading at home
Old 03-30-2013, 07:20 PM
Turbo D's Avatar
What year/model of 6.0l?
Old 03-30-2013, 07:38 PM
Blackpanther99's Avatar
Thats amazing! Good#s!
Old 03-30-2013, 08:01 PM
3pedals's Avatar
06 lq4 shortblock, 09 l92 heads
Old 03-30-2013, 08:16 PM
Jackgtx440's Avatar
Wow, this is awesome. Gives me a lot of hope for the 480.
Quick Reply: Blow through 6.0 S480 - 1067hp
