Build me a budget motor!
Old 04-16-2013, 07:33 PM
Shortbed70's Avatar
Default Build me a budget motor!
I have a 200k 5.3 with 706 heads that didn't smoke or make noise. I'm looking at single turbo, carb for now, cam etc... I have to do this on a budget so lets see what we can do... Going in my ratrod 65 chevy truck, 3.73 gear,26-28" tire 400 trans 3-3500 stall... Race/limited street
Old 04-17-2013, 06:50 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Stock crank, Compstar rods, Diamond pistons, Total Seal rings with steel top rings, ARP head studs, GM MLS head gaskets and find a machine shop that has LS torque plates. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 04-17-2013, 07:24 AM
BMF_Racing's Avatar
How low is the budget? Are you wanting to run stock bottom end or a forged pist/rod combo? Hp goals?
Old 04-17-2013, 08:25 AM
LS5.3stang's Avatar
alot of 5.3s with stock bottom ends with cam, heads and headstuds running 8s in a quarter
Old 04-17-2013, 08:44 AM
Moderator
denmah's Avatar
yeah i would say your motor is already built from the junkyard.
i have a friend running 9lbs of boost on street tires in a 5.3 fox, stock cam, springs, you name it, just went 11.5 @ 120 lol
and then i have a friend with a 5.3, stock just valvesprings and head studs, twin 57mm ebay turbos and i tuned that car and it went 9.70@ 142 running out of gear. 24lbs of boost
so, what are you looking to do, i would say you are looking to throw out money haha
Old 04-17-2013, 09:07 AM
HRHohio's Avatar
I'd say, stock bottom end, redo existing heads (Larger intake valves and a port job), and get a good cam spec'd. Push 20ish psi and you're in the high 8's to low 9's. Oh... and a big turbo.
Old 04-17-2013, 01:38 PM
Shortbed70's Avatar
CHEAP.... I'm going to re ring and bearing it possibly and a cam... I want less than 2000 in the motor itself... Now what size turbo should I look for budget?
Old 04-17-2013, 01:48 PM
Chicago TDP's Avatar
Put in rings, bearings, dual valve springs, LS9 head gaskets and studs.
If you have modest power goals, 70-76 MM, .96 A/R.
Old 04-17-2013, 03:31 PM
Twin turbo c5's Avatar
Run it bone stock. If your on a budget. Those motors are tuff run it.
Old 04-17-2013, 03:51 PM
HRHohio's Avatar
I have a 2005 4.8L that I'm building right now ($450) for a 72 Camaro. I did the rings and rod bearings (<$200), put in a 228/234 cam (~.600 lift) on 114 LSA ($375), and the heads ported, decked, new springs, and new (2.02 intake) valves ($1200). Same boat as you... l have right around $2k in the motor. I'm putting on Twin On3 70mm Turbos. (Inspired by Wicked69 and his Chevelle).
Old 04-17-2013, 03:52 PM
Moderator
denmah's Avatar
yeah i mean i thought 80 dollars was cheap enough
Old 04-17-2013, 04:18 PM
HRHohio's Avatar
Hahaha... So true!
Old 04-17-2013, 04:44 PM
Sarg's Avatar
What is your budget for the turbo. I consider the S400 series Borg Warners a steal for what they are. You can get a 1000 hp capable turbo for right around $800-$900. If you are wanting less than 700 hp, the On3 76mm for $350 is a good choice or the Ebay GT45 turbos with their larger turbine wheel. I would not worry about heads...just turn up the boost another psi!
Old 04-17-2013, 07:37 PM
You got me beat Matt .I got 300 in my 6.0 but I only paid 150.00 for my fairmont running with the 6cyl. I was planning on building a Ls motor but these junkyard motor won't die and my 6.0 keeps gettin faster.
Old 04-17-2013, 07:39 PM
I8UR4RD's Avatar
AES has 2899 forged 5.3 shortblocks.
Old 04-17-2013, 11:11 PM
Shortbed70's Avatar
If I knew more about the motor I would run as is with head studs, gaskets cam/springs but it was supposedly using oil so I suspect rings gummed up in lands on pistons so I'm gonna pull it apart before it goes in. As far as turbo, 500 ponies is fine with me so don't need anything to large... Like I said this truck is rough and I want the motor to kinda look rough also! I don't even want to clean the heads or block before it goes in... Just want a couple camaros here to eat smoke from a pile of crap.. Acquaintances of mine!
Quick Reply: Build me a budget motor!
