Who has the best JY 5.3 turbo cheap on here
The "cheapest" way would be to use a stock 5.3 change intake mani and a couple other small things. Use the On3 performance turbo system TH 350 or 400 and a Ford 9in out of the jy. can be done very cheap but reliablity? thats the question. Best of luck!
i have done a ton of 600+ whp 4.8 and 5.3 cars
pac1218 springs, stock or custom cam, kmj studs, ls1 steel head gaskets
"denmah" kit from VSracing
9 sec fox and 3rd gen camaros on stock longblocks is very easy
What kind of rough idea $ are we talking probably? I would kill to get into the 9's, but happy with 10's to....Thanks man
my friends fox was completed for under 5k, could have been under 4k but we broke a few th400s and burned up a few shitty converters.
if you can weld and tune and wire you can do it for less than 2k to an existing vehicle.
"just" 600 whp
i dont have the track video but this car went 9.7x @142 and ran out of gear at the 1000ft
650rwhp on a stock cam, stock heads, stock intake, 5.3
just studs and valvesprings
"just" 600 whp
yeah. I can afford it, it's just the principal of it that is making me reluctant you know. But still the good thing is I can replace any major component on mine for less than $400. engine, trans, turbo, even the truck body itself. it's a disposable racecar basically
I'll have about 5k into my turbo and engine set up. $1650 for Huron Speed kit $1000 PT7675 $350 into my 4.8 with head studs and gaskets. $750 cam kit. $400 intake set up. $500 for misc. I could have cut a lot of corners and cost but I'm shoot for more than 600. Also a 6spd car. Didn't have to go with a Tick Cam and Vic Jr intake or a PT7675.
