lsa head has blocked off vapor/steam hole... why would that be
Old 05-30-2013, 02:24 PM
baggins's Avatar
Default lsa head has blocked off vapor/steam hole... why would that be
I purchased these heads from another member on the board and never realized this until now. Heads are brand new, why would this be
Old 05-30-2013, 02:26 PM
baggins's Avatar
Its almost like a rivet type thing
Old 05-30-2013, 04:51 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Doesn't the LSA use piston squirters to keep the pistons cool? Maybe they felt they didn't need the extra flow there, just a hunch.
Old 05-30-2013, 04:53 PM
stevieturbo's Avatar
Possibly internal waterways are different and less susceptible to airlocks at those locations.
I'd still be inclined to drill it out and use them though unless you were sure of the above.
Old 05-30-2013, 11:50 PM
baggins's Avatar
Only one of the four holes has this rivet thing, just gonna knock it out and run the vapor lines
Old 05-30-2013, 11:51 PM
westtexasbuff's Avatar
Mine don't have that....
Old 05-30-2013, 11:52 PM
a4ls2goat's Avatar
my 2008 4.8 with 799 heads are blocked off like that too.
Old 05-31-2013, 01:26 AM
Moderator
denmah's Avatar
i believe its a sign from the chevy gods telling you to disregard steam ports
Old 05-31-2013, 02:48 AM
Perhaps, but those same gods arent ramming boost into their engines and developing heat and hot spots in the same manner many here are.
IMO it isnt difficult to use them and it makes sense to do so.
Old 05-31-2013, 03:01 AM
Nitroused383's Avatar
LS3 heads are the same way.
Old 05-31-2013, 09:49 AM
7 Second Club
NicD's Avatar
It's cheaper to use an insert like that than to use the external bolt and plug like on the earlier heads. They still only block off the rears and leave the front open for the crossover, etc. You have to knock it out with a hammer and punch while the head is off though as it comes out the bottom and not through the top if you want to join the steamports all together.
Quick Reply: lsa head has blocked off vapor/steam hole... why would that be
