JAX04s 00'GT AES347" Twin 66/65 Street Terror
Old 06-29-2013, 02:53 PM
JAX04's Avatar
Default JAX04s 00'GT AES347" Twin 66/65 Street Terror
Figured since things changed so much id just start a new thread and keep this one up to date..
2000 Mustang GT Cobra and Steeda all over
AES347" Callies Diamond ARP Jazz
Huron Speed Turbonetics 66/65
TSi Powerglide with brake
3.08 Rear End
Holley Dominator
Edlebrock Proflo
etc. etc.....
Sumped Factory Tank
Old 06-29-2013, 04:00 PM
I8UR4RD's Avatar
this is badass.
Old 06-29-2013, 04:07 PM
LilJayV10's Avatar
I thought the car had some goofy rear wing on it then I realized it was a grill.
Looking forward to the build.
Old 06-29-2013, 05:34 PM
rwb
rwb's Avatar
The grill is a goofy wing on the rear, it's for when he needs to actually bbq the remains of those he races.
Old 06-29-2013, 05:36 PM
JAX04's Avatar
Thanks guys, the goofy wing on the back is a svt cobra wing, the trunk is popped
Old 06-29-2013, 05:53 PM
Blackpanther99's Avatar
This cobra is gonna end up being a beast! Love how the snails are mounted on there.
Old 06-30-2013, 12:31 PM
1fast bird's Avatar
Looks great man!!! Should be awesome when it's done
Old 06-30-2013, 12:49 PM
02LS1ram's Avatar
Very cool build, def likey the turbo placement. Few more details on the AES 347! What kinda price tag on it. Pm me if needed. I tried getting ahold of them once before for a 347 and never got a response.
Old 06-30-2013, 01:20 PM
allout06's Avatar
subd man. we'll have to get together when ours are both done! interested to see how the tc66s do on a 347 im using the same set on a 390 which u know! .good luck !
Old 06-30-2013, 01:35 PM
JAX04's Avatar
Thanks man! I been following you your too, love those trucks!
Its a 5.3 ally block bored to 3.905 with callies rods and diamond pistons. My thinking was, the block is gonna give up before the crank... We shall see. The price was inline with everyone else, TSP etc. When price checking them, be sure to choose the proper things, rings, pistons, main studs, etc.
Yes! YES we will have to get them together when they are done! Are you pretty close to getting them wrapped up?
Thanks again guys!
Old 06-30-2013, 02:17 PM
allout06's Avatar
Thanks again guys!
eh... im poppin the motor in hopefully on wednessay and im reluming the harness today. itll b next spring before mines done . but it'll b worth the wait i think. check out my thread, i updated it the other day. whens ur gonna be done ?
Old 06-30-2013, 03:51 PM
JAX04's Avatar
Well... Thats a good question haha. I would estimate it should be on the road in the next couple weeks. Now that the motor is in, i should go fairly quick, pending no issues, I get real unmotivated when its stupid humid and hot in the garage...
We shall see.
Old 06-30-2013, 07:59 PM
turbocamaro125's Avatar
Jax how do you think the rad is gonna work? Cooling wise I mean...explain everything! Lol what fans? Where's the fill gonna be? What size rad? You know...everything lol
Old 07-01-2013, 02:23 PM
JAX04's Avatar
No problem, lol
Radiator is 17.5" Tall by 30" wide x 3" thick Dual pass
For the fill line im considering two options.
1. Extend a tube from the top of the water pump and put a cap on it.
2. Put it inline in the upper hose right off the front of the pump like the last setup in previous mustang.
As far as a fan, i'm going to try the stock mustang GT fan and see how that works.
As far as how well i think it'll work?
NO CLUE haha. I HOPE it works great. We shall see. I can see where maybe stop light stuff the temp could creep, but i would bet it'll work great cruising or at speed.
Old 07-01-2013, 02:45 PM
No problem, lol
THanks lol im thinking about a rad setup like that for the BMW and would be cool to save a lot of room laying it down...Hard to tell in the pic but is the rad laid flat or angle alittle?
Old 07-01-2013, 05:23 PM
JAX04's Avatar
It angles up, probably 6-8" or so. Ill be sure to let you know how it works out.
Old 07-02-2013, 10:17 PM
MrPotatoeHead's Avatar
If you're not going to have heat on your car you can cap off the rear heater line and get a expansion tank and run the 3/8 hose to the thermostat side. Then you can run the steam vemt to the upper hose, and tap the radiator for a small 1/4 vent hose that returns to the tank. I plan to use a vw style expansion tank amd get a little higher cooling system pressure while im at it. Everywhere ive read, it says Ls motors run better in recirculating system not the old sbc system.
Old 07-02-2013, 10:18 PM
And any pictures on how you mounted the radiator? I may have to copy.
Old 07-03-2013, 03:30 PM
JAX04's Avatar
Thanks for the info mr. potatohead. Ive not decided yet if im gonna remove the heater or not. My friends want to "go to town" on ripping the guts out of the dash to get the weight down more. Im not sure how hip i am on that idea just yet.
As far as mounting, when i had the radiator made i had them weld 4 1/4x20 bungs on the face of it, i bout some 1/8" x 1" strap and bent it around the radiator and bolted through it, welded them to the chassis and that was it. Once its done, i will add some angle to the corners to make them more rigid and some foam padding between them and the radiator so they dont rub.
Old 07-03-2013, 07:12 PM
If you keep heat, just t into the front hose.
Quick Reply: JAX04s 00'GT AES347" Twin 66/65 Street Terror
