Want to do a turbo build, but no idea where to start.
Old 07-21-2013, 05:56 PM
Endrance's Avatar
Default Want to do a turbo build, but no idea where to start.
Title pretty much says it all. Kind of curious on what the stock bottom end can hold as far as boost, and just hp in general. Also, a big concern of mine, I was going to do LTs, but as far as I know you can't do a turbo with LTs. Can I do it with the LT headers? If not, I'll save the cash and put it into something else. I dont want anything crazy since it's a dd, but I definitely want a tirbo. All insight is highly appreciated.
Thanks in advance,
Endrance
Old 07-21-2013, 08:39 PM
JAX04's Avatar
Their is an AMAZING Section right above this! Its the YELLOW part! Stickies!
My guess, it'll have about everything you need to know about what you are wanting to do...
Old 07-21-2013, 09:54 PM
DEFYANT's Avatar
+ a metric **** ton.
Old 07-21-2013, 09:57 PM
B(o)(o)sted98TA's Avatar
^^^ What they said!
Old 07-21-2013, 10:04 PM
mrstepheneades's Avatar
Unlimited wallet you will need lol... stock bottom here on 12 psi. S475 turbo. Low 500rwhp range on 8psi. Now on 12psi and methanol. No numbers yet. Stock bottom will hold a lot. Just keep good fuel in it and low timing add the meth if needed and it'll live.
Old 07-21-2013, 11:27 PM
GarrettM's Avatar
Every question you have asked is in the sticky plus the answers to all of the questions you don't even know to ask yet. When I started looking into a turbo build I was clueless also, by the time I finished reading each thread in the sticky section I knew pretty much everything I needed to get going I'm a direction. Also, forget the longtubes period unless you decide on a rear mount setup. Good luck and keep us posted!
Old 07-22-2013, 01:20 AM
Burken01's Avatar
LS1Tech 10 Year
Start reading build threads on here, the more you read the more you'll start to understand what your getting yourself into..
my advice, have a daily driver car set aside.. turbo cars have a lot of downtime ($$$, labor, tuning, etc..) its not something that can be done in a couple weekends for most people on here..
Old 07-22-2013, 01:10 PM
GarrettM's Avatar
^^Werd
Quick Reply: Want to do a turbo build, but no idea where to start.
