meth inj or e85 for a midwest car?
I would like to do either or and know the 85 will be a bit cheaper considering I have all the fuel stuff setup for either. I will just need bigger injectors closer to 96lb. I can probably use 80s or 60s for a meth setup. Just a 5.3 stock setup with a 76mm turbo and street car.
But what are your opinions on this?
Should I do the meth inj and if so which kit works effectively?
Or just get a bigger injector and tune it on the 85?
e85 all the way. I have those injectors and ran out at about 17psi. FWIW maybe get a bigger injector if you'd like the headroom. Going with fic2000's next. Also I run dual walbro 255 pumps and that is plenty for my current boost levels.
single digit dreamer
i use this site and plan ahead when going on a road trip. i have never had any trouble finding e85 but you do have to plan ahead a little. http://www.afdc.energy.gov/fuels/ethanol_locations.html
in a pinch you can run pump gas. my cars were always able to compensate with the trims but you wont want to race that way and it is a pain when you do get home because you have to run out that normal gas and get it full of e85 again before you beat on it.
hp with those injectors is 127*8/.75= ~1354hp, not sure on that pump.
Been running e85 for over a year now. If I have to go on long fuel trips then I will run the tank low, fill up with 93, flash my 93 octane file, and go on my merry way. For work purposes I always have my laptop on me anyway especially if I were to go somewhere far.
Only 50. This was on my daily driver 4 cyl.
http://witchhunter.com/injectorcalc1.php
An 80lb injector will act like a 60lb injector at 25psi.
Which will be better? E85 will be easier to tune and safer. But meth injection is more convenient and in the long run may be cheaper.
E85 may be cheaper than premium, but your mileage will be much worse, so you won't be saving on fuel. Also, depending on your area, not every station may have e85, and if you go on any road trips with the worse fuel economy it may be a challenge to keep from running on empty. I have meth injection in my Z, and I fill it up and can rail on the car for every day for weeks straight before I need to fill it again. I've literally spent $20 worth of meth in the last two years (so its cheap). I say its cheaper in the long run because the e85 I'll require bigger injectors and possibly bigger fuel pumps.
But, then again, if you stay in a local area where e85 is easily obtained, then it may be the better choice.
So, it depends on what your are looking for.
if you want max power out of your setup, then go with E85. If you want to drive your car long distances and dont care about losing some power go with 93 and meth.
I take my car on 3hr road trips all the time but there have always been E85 stations where i go. Got 18mpg on one trip when i made it a point not to hit boost, at all, during the drive. It was hard to do though lol
