Do the precision vband in exhaust housings limit power compared to a t4?
I made 1105 rwhp in my vette with a pair of 6265's and v band housings. If i were to build a kit toady i would without a doubt go with the t4 housing if you have the room. I just had to redo my entire kit cause i built a big motor and the .82 AR wasn't going to work well with a 430 ci.
A smaller exhaust a/r will almost always cost you power(but make it spool better). A larger exhaust housing means more flow and less back pressure. Which also usually allows more timing, and more power. A/R is just a ratio of area, the v band inlet housing is considered T3 sized. A T3 and T4 housing could have the same A/R but the T4 flow much more.
I have a customer with a 402/small cam/small head and a pair of vband 6766's and they spool very fast and it makes 900 wheel through an auto at 20 psi on e85
Ive been researching various TT related stuff lately.
And as far as I am aware, their V-Band housings are all based on T3 units, so is unlikely they will be anywhere near ideal, especially for a bigger motor.
The Tial ones go to much larger A/R's although may not fit those turbos.
If you use a very small A/R housing, it only has a tiny hole in it. A housing with a large A/R has a larger hole, hence slower gas velocities into the turbine so less spool. But more flow at the top end.
So it's a balancing act finding what works best overall for each user.
No.
so the turbine wheel wouldn't hurt you if it was small? just run a large a/r with the small turbine?
But if you used a huge turbine with a minute A/R, then the turbine housing would be the restriction.
As I said, it's a balance between them all.
If you choose a turbine wheel that is too large, you'll never get it to spool
I hate to bring this back from the dead, but I have been curious as to why people say the Vband Flange is like a T3?
The inlet area is 6.447 compared to 5.98 on a T4 Non Divided flange.
So IIRC, the .81 T4 flange should be tighter on flow that the .82 THV housing.
Does that make sense? Also there are 2 different ARs now, the .63 and .82 housing.
The t4 flange is much larger then the "t3 sized" v-band inlet housings. Precision also calls them "t3 sized".
