***74 Nova*** 5.3L Single Turbo Build
Old 08-19-2013, 06:42 PM
ISprayOnU's Avatar
Default ***74 Nova*** 5.3L Single Turbo Build
I just bought 2 5.3L motor for $500. Im using the one 5.3L motor that has 243 heads on it alrdy. Having trouble finding what to do as in forgeing the motor.
The plan:
T76 or T78 turbo
Using trick performance turbo manifold (pass header)
45mm Wastegate
Bov
3" intercooler
75Lbs injectors
Holley Hi-Ram Intake 102mm
102mm TB
243 ported heads
ARP head studs
Ls9 head gasket
Th400
10 Bolt rear end or 12 bolt
E-85
Aeromotive fuel regulator
Aeromotive a1000 fuel pump
20Gal fuel cell
Thats all I got for now. Would some guys that alrdy did 5.3l turbo build. What forged internals should I use? What oil pan is going to fit on the nova?
Old 08-20-2013, 09:13 AM
Chicago TDP's Avatar
I do not want to rain on your parade ...just need to know why you are going to buy the hi ram and 102 throttle body?
I would run the 5.3 STOCK with a better cam and PRC .600 dual springs
Get a LS1 intake and aluminum rails if you cannot find a completed stock intake on ebay complete.
Bolt on the stock truck throttle body.
Saving money on the intake and throttle body will allow you to buy a better turbo.
Sell the 243 heads as well, you are going to have almost no gain with them VS stock 5.3 heads...the 243 heads might actually drop the compression which is going to hurt you in the turbo lag department and you will need to have that "tuned" out.
Get a good turbo like the newest T-netics TC7675 .96 AR or a Precision PTE 7675 CAE billet .96 AR....bigger money but the turbo makes the car, not the motor.
If you can, you need a LS1 camaro pan and it needs to be notched 2.5" I believe (check first).
Otherwise, get an aftermarket pan or GM muscle car pan...the rear steer center link on the Nova is a bitch to work around.
Just my 2 cents...built a few of these cars now and the money is best spent in four places : Turbo, tuning, trans, fuel system
Old 08-20-2013, 11:26 AM
ISprayOnU's Avatar
I would run the stock motor but the guy I bought them from doesn't know if they run or not so I was just going to forged while the motor out. They have no cracks on the block.
I seen a lot of the 5.3 turbo build use the hi ram 102.
Should I get 317 heads? The other motor gots 706 heads on it
Old 08-20-2013, 11:43 AM
TDMKR496's Avatar
What is your HP goals? You really don't need any forged internals unless you plan on going north of 700 hp IMO.
Old 08-20-2013, 11:55 AM
87silverbullet's Avatar
^^^^All of this. Except for the oil pan. You can use a truck pan or use the AutoKraft pan. My buddy has that in his 67 camaro and stock 48 on here is using it too on his nova that we all know is moving at 8.39@164!
I would just use an ls6 intake for this setup. stock48 is using the stock truck intake.
Old 08-20-2013, 12:26 PM
HRHohio's Avatar
Here's some piston info if you're dead set on replacing pistons:
Wiseco makes a "drop in" replacement piston for the 5.3 called the "junkyard dog".
http://www.wiseco.com/Catalogs/Automotive/Chevrolet.pdf
available at TSP:
http://www.texas-speed.com/p-4180-wi...rist-pins.aspx
BUT if it were me, I'd open it up, inspect the existing pistons and if there's no busted pistons, button it back up and run it. For the cost of the Forged pistons, you can replace the short block almost twice, or get a 6.0 LQ9. Even if one of the pistons is bad, you can get a new "used" piston on Ebay for $40. Stock pistons have been run at >1000 hp. As long as your tune is spot on.
Good luck!
Old 08-20-2013, 03:55 PM
ISprayOnU's Avatar
I want to make about 1000rwhp.
So the stock 5.3 oil will work on 74 nova?
I think im going with the forge "junkyard dog" pistons. Im going to take the motor apart and make sure nothing damage.
Whats the best Intake and heads to use?
Old 08-20-2013, 06:50 PM
Blackpanther99's Avatar
Oh yeah. Youll need to forge that block. Lol
Old 08-20-2013, 07:02 PM
Pete91's Avatar
Is this gonna be a street car? 1000rwhp is a lot of power, if you are planing to drive the car in the street I would say shoot for 6-8 hundo because you're gonna have a lot of issues trying to stick 650rwhp down. 1000rwhp is pointless unless you like doing sideways smoke shows at 80-90mph
Old 08-20-2013, 10:28 PM
ISprayOnU's Avatar
I want the car to make 1000rwhp but turn down the boost driving it. Its going to be a street/drag car.
If I forged the stock block with the "junkyard dog" pistons I should be able to run 20 to 25psi easy right? I should make 1000rwhp.
Does anyone know if someone done the junkyard dog pistons on 5.3L turbo build and what they put down?
Old 08-20-2013, 11:18 PM
HRHohio's Avatar
Have you seen what the stock pistons are capable of? With enough octane and the right tune:
http://www.hotrod.com/techarticles/h...g_bang_theory/
Old 08-21-2013, 06:40 AM
TDMKR496's Avatar
My Chevelle makes a little over 1100 to the tires @ 19 psi and its totally useless on the street unless you like doing burnouts at 70 mph. Even @ 10 psi it still spins the drag radials pretty bad. Be careful what you wish for.
Old 08-21-2013, 07:47 AM
JAX04's Avatar
Old 08-21-2013, 08:04 AM
68 SS's Avatar
The truck oil pan is not what you want to use, you can use the F-Body pan or Holley makes a new pan that will work. The truck pan hangs way too low for most all muscle car applications. Some notching of the sub fram may be needed dependin on what mounts you use.
Old 08-21-2013, 10:05 AM
ISprayOnU's Avatar
Just stock ls1 f-body oil pan? Whats the best mounts to go with?
Old 08-21-2013, 10:10 AM
HRHohio's Avatar
Dirty Dingo makes a nice product.
http://dirtydingo.com/store/index.php?cPath=323
I bought a pair for my 72 build... GREAT QUALITY... (still in box right now)
Old 08-21-2013, 10:12 AM
You're just not on the correct street.
Old 08-21-2013, 10:34 AM
Beanslsxnova's Avatar
Are you looking for polyurethane or solid mounts? I went threw all kinds of **** trying to get rid of the clamshell mounts on my 73. I can tell you what works and what doesn't lol
Old 08-21-2013, 11:23 AM
TDMKR496's Avatar
lol, this is true....
Old 08-21-2013, 12:00 PM
Quick Reply: ***74 Nova*** 5.3L Single Turbo Build
