Intercooler swap gains 168rwhp
#41
What does it pickup ait wise going down the track? I have a large garret core to build for my car, but I don't have it running yet, I have used them on plenty of big power 4 bangers with great results.
I have seen the treadstone work well on some fast 4 bangers as well, seems to be a good budget core for sure.
I am goin to the track tonight with a friends turbo mustang (800rwhp) with one of the ebay special 4" thick cores, The aits rise like crazy on the interstate, I will post up the data from the track later tonight.
Fathouse
Fathouse
#42
The mustang didn't run that good, its a stick car and had problems shifting so it spent alot of time not spooled. 331sbf, gt42-76, e85 ~20psi made 800 wheel.
The ait picked 70 deg on a 1/4 mile pass, its the 4" core.
Fathouse
Fathouse
#43
I just picked up a D1 car and will be looking at swapping to a fmic for a number of reasons, looks being a big one! LOL
I had a CX 31x12x4 fmic with the 3" in/out and made 949rhwp on 110 oct and 700rhwp on 11psi & 93 oct.
For $100, i will be using it on this car as well!!
#45
What was pre/post temp and pressure skinnies? 100* off is a good number, but not if outlet temp is in the 300s.
Pressure drop can be misleading. It's a double edged sword. You need drop in order for it to do its job- Cooling the charge- but too much results in loss of HP.
#46
Would be interesting to see more back to back results
#47
i wouldn't expect a whole lot more to have been had. it was just a truck mani kit with stock heads, a mild cam and a vic jr on 22 psi, nothing exotic or high flowing about it. obviously i could be wrong, but i was pretty pleased with 949 on a conservative tune as the car saw more street cruising than track. the OP is my tuner and seemed pretty impressed with the simple combo's output
#48
Also alot of mis-information going around about the CXracing cores. On the standard universal 31x12x4 with 3" inlets/outlets we saw 3.5psi of back pressure at 20lbs of boost.
I'm sure I could pick up some power with a nicer aftermarket IC. Just not worth it for my application.
My cooler was $125 shipped. For the money spent... it works very well.
#49
I think the 9" version and my bumper cut more would make a big difference. I talked to treadstone about the 6" intercooler when I got it, they said I should be able to shove 1200rwhp through it, just isn't ideal. They told me iats would go up, but restriction shouldn't be an issue and so far it hasn't been.
#58
Guys may I advise you to use Motorola differential sensor? That would be precise and easy to setup, just find 5V source and connect 2 pressure sources. Don't have to worry about different gauges reading different anymore.
I used MPX5050DP, 7.5psi range, it puts out 5V signal you can log
