Another twin turbo s10 build
Old 09-10-2013, 11:35 PM
Dragtruck2's Avatar
Default Another twin turbo s10 build
I have been collecting parts for a while, here is what I have done so far.salvage yard 6.0, arp main studs and rod bolts ,317 heads with home port job and decent springs, small comp cam 54-428-11, high ram intake, 80 pound injectors, aeromotive pump .Installed TRZ lower control arms and springs, also fabbed in a rack and steering column now I just need to finish it
Attached Thumbnails Another twin turbo s10 build-20130227_11.jpg   Another twin turbo s10 build-20130317_14.jpg   Another twin turbo s10 build-20130601_8.jpg   Another twin turbo s10 build-20130601_10.jpg   Another twin turbo s10 build-20130317_3.jpg
Another twin turbo s10 build-20130829_4.jpg   Another twin turbo s10 build-20130829_11.jpg   Another twin turbo s10 build-20130829_21.jpg   Another twin turbo s10 build-20130829_2.jpg
Old 09-11-2013, 07:03 AM
Black98s10's Avatar
Looks good
Old 09-15-2013, 03:41 PM
Dragtruck2's Avatar
Using alot of sloppy Mechanics Ideas like micro squirt 2 ecm and his tune up for E85. Denmah shows that it works.I will just put it together a little less sloppy.Hope to be out in the next month.
Old 09-15-2013, 05:24 PM
Blackpanther99's Avatar
Im guessing this will be on Pump Gas?
What turbos?
Old 09-15-2013, 05:37 PM
Tuckin15s's Avatar
Awesome Project in for updates!
Old 09-15-2013, 07:06 PM
T76s10's Avatar
What turbos?
im wondering the same thing. reminds me of a certain black second gen on here also with a lq4 and twin turbo
Old 09-15-2013, 10:45 PM
Dragtruck2's Avatar
Running cheap turbos, GodSpeed 72s on e85
Old 11-30-2013, 06:05 PM
Dragtruck2's Avatar
Got the motor and trans installed . Now I need to find time to finish brake lines and wiring.
Attached Thumbnails Another twin turbo s10 build-20131103_10.jpg   Another twin turbo s10 build-20131103_19.jpg   Another twin turbo s10 build-20131103_2.jpg   Another twin turbo s10 build-20131103_23.jpg   Another twin turbo s10 build-20131118_23.jpg
Old 06-03-2014, 04:31 PM
Dragtruck2's Avatar
Made some passes but I think I ran out of injector, I have 80 lb injectors on e85 at 8 lbs of boost and it started at 9.98 and went to 9.54. Every pass was lean so I would bump up fuel pressure ,it stayed lean just went faster.
Attached Thumbnails Another twin turbo s10 build-scan0006-480x382-.jpg   Another twin turbo s10 build-20140518_26-480x360-.jpg
Old 10-01-2015, 04:11 PM
silverbulletman's Avatar
What cam are you running in that combo ?
Old 10-01-2015, 04:38 PM
Drewstein's Avatar
Holy Necro
Old 10-02-2015, 08:10 PM
rpturbo's Avatar
Wow, I love this truck!
Old 10-06-2015, 01:29 PM
Forcefed86's Avatar
What did you do for a radiator? Any shots behind the turbos so we can see the routing?
Old 10-06-2015, 02:08 PM
IronBlocked's Avatar
That coldside looks so good uuuugh
Old 10-06-2015, 02:50 PM
DavidBoren's Avatar
Needs a 417 motorsports a2w intercooler sandwiched between the base and lid of that holley intake.
Did you put the radiator in the bed?
Old 10-08-2015, 08:41 PM
Mike Prychka's Avatar
awesome truck man, i love s10s my builds has been sidelined because i totaled the truck earlier this year and just finally got back to work, due to being injured from the accident.. good luck and keep us posted with updates and pics if you can.. thanks
also what headers are you using, and how do they fit?? like your setup alot. LOVE THE COLOR too.. any more details on the rest of the truck, like suspension etc? just curious
Quick Reply: Another twin turbo s10 build
