How big fuel lines for 700 whp E85?
Old 09-12-2013, 01:14 PM
Turboswede's Avatar
Default How big fuel lines for 700 whp E85?
As topic, how big fuellines do I need for a turbo 5.3 lm on E85 do I need?
Im think about an8 as feed line and an6 for return, would that be enough?
Old 09-12-2013, 01:24 PM
smokeshow's Avatar
Yes, that will be sufficient.
Old 09-12-2013, 04:51 PM
Martin718's Avatar
rule of thumb is generally E85 flows or requires 30% more fuel to make equivalent power as on pump.
i would recommend -10 for supply and -8 for return... make sure pump is large enough and clean injectors and rebuild pump annually..
Old 09-12-2013, 05:19 PM
Busa_rob's Avatar
I would strongly disagree with this. I have 6-700whp 1300cc turbo motorcycles using -6 feed and return on E85. -8 is plenty to do the job anything less then 1100hp.
Old 09-12-2013, 05:36 PM
LS1Tech Premium Sponsor
Dave@WS6store's Avatar
you can make over 700rwhp on e85 with the stock rails AND lines in a fbody. Been done countless times. But yes a -8 would be MORE then sufficient to get to your power goals depending on your injectors.
Old 09-12-2013, 06:21 PM
LS1RedZ's Avatar
Yeah -8 and -6 if u do anything. What pumps? I'd recommend the dual walbro 340s, if u want room to grow.
Old 09-12-2013, 06:57 PM
Turboswede's Avatar
Thanks guys sounds great first I thought about dual aem 320 in tank. But the car will be used also for drift and track so I'm thinking about a walbro 450 in tank (maybe a aem 320 would be enough?) to a surge tank and then two external pumps from surge to fuelrail. No idea if its best choice to use twins or one big single like a magnafuel 4301.
Old 09-12-2013, 08:17 PM
smokeshow's Avatar
I was going to say this...figured people would get their panties in a bunch though lol.
Old 09-12-2013, 09:30 PM
CameronVic's Avatar
8 feed, Y to -6 for the rails, and -6 is exactly what I have. You'll be perfectly fine.
Old 09-13-2013, 12:11 AM
oakley6575's Avatar
Tends to happen here quite easy.
A lot of guys are running 1000whp set ups with a -8 feed. Should be more than enough.
Old 09-13-2013, 07:19 AM
Black98s10's Avatar
Would e85 and e98 require different fuel systems, or are they one in the same?
Old 09-13-2013, 08:24 AM
89ROC-Z's Avatar
Just use the schraeder valve port as the return? I'm interested in this!
Old 09-13-2013, 08:59 AM
dmaxvaz's Avatar
my experience would be -10 feed, -8 return. think of doing it once and not multiple times when you want to go bigger.
Old 09-13-2013, 09:44 AM
Turboswede's Avatar
Whats youre suggestions a single magna fuel 4301 or dual smaller pumps?
Old 09-13-2013, 11:13 AM
dmaxvaz's Avatar
get the holley dominator 12-1800. ultra quiet, and did not run out of pump at 801 rwhp with 1000 cc injectors (ran out of injector to make more power).
Old 09-13-2013, 12:10 PM
samdogmx's Avatar
I run -10 feed & -10 return. I also run the holley dominator 12-1800 pump, you can't even hear it over the exhaust its so quiet.
Old 09-13-2013, 12:15 PM
Turboswede's Avatar
How do you wire them up? So they flow all the time? From what I can read they sounds great.
Old 09-13-2013, 12:27 PM
Martin718's Avatar
this was my point, nobody ever seems to leave anything alone so why not do it once that will support whatever future mods, buy it once, install it once, take all doubt out once....
to each its own
Old 09-13-2013, 12:36 PM
dmaxvaz's Avatar
wire them up together and run them all the time (use a 40 amp relay from casper electronics) and they give you directions how to wire them (holley does)
Old 09-13-2013, 12:41 PM
samdogmx's Avatar
my 1st stage runs all the time the second is turned on by the PCM once I go above 60% TPS & 2psi of boost
Quick Reply: How big fuel lines for 700 whp E85?
