Twin turbo oil return
As long as the flow path is clear and gravity fed to above the level of oil, go with it. Min 1/2" diameter line.
If the path isnt as smooth or clear as you'd like, go larger. Oil journal units will go through more oil flow than a ball bearing unit too.
