junk yard 5.3 turbo records?
Old 10-13-2013, 08:52 PM
n20z28's Avatar
Default junk yard 5.3 turbo records?
What's the record for junk yard 5.3? My setup is bone lm7 with stock rings and ARP rod bolts and ARP head studs with 224 tx cam and stock 5.3 heads and ls9 gaskets... s480 etr...
I made 833/721 this weekend through slicks and. Th400 think about upgrading fuel system and going for 1k?
Old 10-13-2013, 08:59 PM
X-Bomb Racing's Avatar
Old 10-13-2013, 09:01 PM
What casting # heads?
Old 10-13-2013, 09:02 PM
n20z28's Avatar
What was dyno record... that car is bad but its also a full methanol dry hard blocked...
Old 10-13-2013, 09:05 PM
n20z28's Avatar
862 I think lol I double check in morning... I know there 5.3 heads and are unported
Old 10-13-2013, 09:07 PM
Thats what they probably are. Thats what was on mine. Just got them back from the port shop today. Those are decent numbers you made. What kinda dyno was it?
Old 10-13-2013, 09:11 PM
n20z28's Avatar
Dyno jet
n20z28's Avatar
My a1000 ran out there
Old 10-13-2013, 09:12 PM
Congrats on the numbers! doing something similar to put into a rx-7. Im shooting for 8-900 whp
Old 10-13-2013, 09:30 PM
n20z28's Avatar
Thank s.... hopefully we get c some times this weekend with the first time on track... then I'm going upgrade fuel and try bigger number and go faster..
Old 10-14-2013, 07:23 AM
Photochop's Avatar
lsx3151 on here did 996rw thru a 4l80e, same cam as you with a billet pt7675 at close to 30psi. Same cam as you on a pre '05 shortblock. Here's a link
https://ls1tech.com/forums/forced-in...yno-video.html
Your car runs stout and makes great power! What intake/fuel system/converter and turbo? Is that a 83/80 etr? What a/r?
Old 10-14-2013, 08:10 AM
MMWS6's Avatar
There was a 5.3 junkyard turbo on HP a few months back made just a hair under 1k to the wheels. Most I've seen anywhere yet... ^^^yup, that's the one...hahaha Bloody insane is what you guys are
Old 10-14-2013, 12:07 PM
LS1TECH Sponsor
DrTurbo's Avatar
Upgrade the fuel and she will do it. That ETR-HO 80 will make the power no problem.
Old 10-14-2013, 12:51 PM
mrstepheneades's Avatar
The new 84mm you were speaking about... with a smaller a/r on a 5.3 how much boost will it pump out. I traded for a complete 5.3 that I will forge. Or is 80 ho etr better choice for a small cube high boost app? Thinking the 5.3s may handle more boost load than the bigger bores.
Op how much boost was that to make 833? Fuel?
Old 10-14-2013, 08:36 PM
n20z28's Avatar
Jose u are correct I think I got it... we had very little timing in motor..
Old 10-14-2013, 08:39 PM
n20z28's Avatar
Your car runs stout and makes great power! What intake/fuel system/converter and turbo? Is that a 83/80 etr? What a/r?[/QUOTE]
Stock ls2/ a1000 on e85 / convertor is ???/ etr billet 80 1.32 t6
Old 10-15-2013, 07:15 AM
RedRocketZ28's Avatar
How much timing was in it? When does the turbo spool on the 5.3? I am probably going with a S480 of some sort over the winter and if my LQ4 lets go I will swap in a 5.3.
Old 10-15-2013, 01:55 PM
n20z28's Avatar
14* 3800ish
Old 10-15-2013, 02:04 PM
Black98s10's Avatar
I'm also curious on what boost you were pushing and fuel to get the 833hp?
Quick Reply: junk yard 5.3 turbo records?
