Procharging this LQ9
TOTM: June 2007
hey guys.
I dont spend much time posting here, just lruking like a creep. I spend alot more time on performancetrucks.net. I asked this question over there, but never really got the answers i was hoping for.
MY toy truck has a lq9 with the following specs
LS62.5 Precision Race Components CNC Stage 2.5 LS6 Cylinder
Heads, Bare - 62cc Chambers (SERIAL#16923)
2.02-Inch Stainless Steel Intake Valve, Per Valve 12.00 96.00
Inch Stainless Steel Exhaust Valve, Per Valve 12.00 96.00
PRCSpringKit PRC .650' Dual Spring Kit complete with seats, seals, and
retainers
Torquer v.3 Texas Speed Torquer V3 Camshaft - 231/234 .643/.598
111 LSA..*Requires Aggressive Double Springs!
Texas Speed & Performance 7.3750 Hardened
Chromemoly Pushrod, Per Pushrod
GM 6.0L MLS Gasket, PER GASKET 40.00 80.00
ARP Hex Head Bolt Kit, LS2 & NEW 6.0L Blocks ONLY! 113.95 113.95
GM LS2 Lifter Tray 8.09 32.36
GM LS7 Lifter Kit 139.99 139.99
LS6PortedPump Texas Speed & Performance Ported & Shimmed LS6 Oil
Pump
LS2ChainSet LS2 Timing Chain, LS2 Timing Chain Upper Sprocket,
LS2 Timing Chain Lower Sprocket
COMP Cams LSx Rocker Arm Trunion Upgrade
TRuck is currently undergoing a t56 magnum swap, has 4.56 rear gear, and all other sorts of ****
My question is Does anyone think I can run any boost on this setup with its compression? Im not looking to make big power, just add some more and have some fun doing it. Love working on the truck, and would be a fun add on
thoughts and concern are welcome
my rcsb
retainers
Pump
my rcsb
Way to copy and paste your specs, including the prices straight from a dealers website.
You post that setup, and then ask about your compression without putting in anywhere in your specs.
Stock pistons?
Stock pistons?
LS1Tech Sponsor
7 psi with methanol and a good tune I wouldn't expect you to have any problems. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
TOTM: June 2007
Thanks for the advice guys
