Cam ??? for Ly6 with twin 76mm turbos.
I have a tube chassis all fiberglass 1957 Chevy I am building
For 60 street and 40 strip. I'm trying to see what specs would help
Spool these large turbos on the 6 liter??? I will be building a 427 soon but
Want to run the 6 liter for a while to setup fuel injection and suspension
Is it duration or lobe center or lift tht helps spool turbos???
I know the twin 76mms are large for a stock 6 liter with l92 but the plan is to build a larger cubic inch later.
Car specs
6 liter l92
L76 intake
Turbo 400
3.08 gear
Car weight should be 2900 lbs or so
Thanks Kerry
Car specs
6 liter l92
L76 intake
Turbo 400
3.08 gear
Thanks Kerry
Appreciate the offer but I have built several turbo cars, I built chassis and all from ground up. The problem is I know these 76mm with .81 exhaust housing are I little big for 6 liter so I want to find a cam that will help in the spooling of these turbos. I would have gone with twin 70s and it would have been great but being im planing on building a larger motor in the future I went with the 76mm. The main thing I'm looking for is what parameters of the cam help spool the turbo. Is it more duration or lobe center???
Do you go to No Problem? if so we need to meet. Thanks Kerry
twins
T4 flange
Compressor Trim: .80ar ; Compressor wheel ind/exd dia.: 76.7/102.3mm
Turbine Trim: .81ar ; Turbine wheel ind/exd dia.: 64.5/74.5mm
twins
T4 flange
I mostly go to Gulfport just Bc it's closer. I work in metairie so maybe one day after work we can meet up. Are those the on3 turbos? I ran one of those on my 5.3 a while back and it ran a 10.9 @ 125. Now I have the gt45 80mm. I don't see you having a problem spooling them. My buddy does it just fine with his t56 ls1 camaro
I was looking at the Tu3 cams or Cam motion is right down the road from me, they cut my last turbo cam. I think I will see what Stock48 and Martin have to say ... may just get one from one of those guys .. I know they say the cam profile can help spool larger twin turbos I read on a thread where Lil John or martin was talking about it ...
I need to order one this week ..... the chassis is coming together pretty quick. I need to put LS9 gaskets head studs and cam and Im ready to put motor back in for the final time ..
My TU1 works very well in my 5.3 but Im sure you would be better off with a little split since you have rectangle port heads. I can tell you that Martin and Jarrett are going to have different opinions on cam size. From what I have seen Martin generally like bigger cams than the norm, which Im all for lol. I would say get either one to help you spec it out and get cam motion or bullet to grind it bc they both have a quick turn around.
