Melted steering intermediate shaft/knuckle!!
Old 12-07-2013, 08:32 PM
brianfromhawaii's Avatar
Default Melted steering intermediate shaft/knuckle!!
hey so I need some advice here... my turbo piping melted the rubber out of the steering knuckle!! I ordered a new one, but it is going to melt again! any advice? ideas?
any companies make aftermarket ones?
I tried to weld it, but one part is steel, one part is aluminum... obvious problems
Old 12-08-2013, 04:30 AM
stevieturbo's Avatar
Post a photo.
Any heat management in place ?
Old 12-08-2013, 07:33 AM
wild1100's Avatar
What manifolds are you running
Old 12-08-2013, 12:36 PM
no pics yet, but it melted here. one part is steel, the other is aluminum, held together by rubber.
Attached Thumbnails Melted steering intermediate shaft/knuckle!!-knuckle.jpg
Old 12-08-2013, 01:01 PM
HexenLord's Avatar
Go get some header wrap and wrap your hotside piping. It'll cut down temps greatly.
Old 12-08-2013, 04:16 PM
cant do that in this situation.
Old 12-08-2013, 04:29 PM
So have you any heat management in place at all ?
if not, then obviously you're going to keep melting things
Old 12-08-2013, 10:24 PM
the down pipe is notched to fit around that part. its the only part i cant wrap.
Old 12-08-2013, 11:34 PM
LILHEMI's Avatar
Time to redesign your downpipe lol
Old 12-09-2013, 03:49 AM
ummm.... no, there is no other way to design it unless i dropped it from 4 to 3 inches...
Old 12-09-2013, 04:13 AM
There is always a way. What turbo are you using ? A big single ? Where is it mounted ?
Old 12-09-2013, 12:01 PM
s480 mounted right infront of the engine, exhaust side twords drivers side because i keep AC, i just need to make this steering thing solid...
Old 12-09-2013, 12:22 PM
Well I guess you could dismantle it, remove any rubber and weld it back together.
Or have a new section fabricated.
Doesnt look like it would be that difficult to do.
Old 12-09-2013, 02:20 PM
its steel to aluminum
Old 12-09-2013, 03:43 PM
Which bit is steel and which bit aluminium ?
Old 12-09-2013, 09:51 PM
in the picture, the part to the left of the main shaft.
Old 12-10-2013, 05:06 AM
A little odd for steering parts to be aluminium, especially a UJ like that
You can buy universal UJ's for motorsport applications, so I guess you could just fabricate a complete new piece
Old 12-10-2013, 08:43 AM
sparkwirez06's Avatar
buy a borgeson or flaming river u joint all billet needle bearing, remake the steering shaft. http://www.summitracing.com/search/p...ing%20U-Joints
Old 12-10-2013, 02:44 PM
i think i am just going to use an lt1 steering knuckle
http://s103.photobucket.com/user/the...RACKS.jpg.html
Old 12-10-2013, 05:24 PM
If it's the top one, it looks to have a rubber section too.
A common piece on a lot of cars, although I have heard of some replacing it with solid.
Quick Reply: Melted steering intermediate shaft/knuckle!!
