Post your BW S400 dyno graphs/ ET here!
For those of us who are considering a BW it would be nice to have a log of other's results with details on the build to make a better informed decision of the appropriate turbo for ones goals and the graphs will allow us to see where boost comes in.
Post your details and dyno graphs here, along with the following details on the build:
Turbo: S4XX (T4 or T6, A/R, turbine wheel size, race cover, billet wheel, ported housing etc.)
PSI:
Cubic Inch:
Transmission:
Compression:
Fuel:
Heads: (size/casting/brand/ported/valve job etc.)
Intake:
TB size:
Meth y/n:
Intercooler size:
ET/mph:
RWHP:
RWTQ:
PSI:
Cubic Inch:
Transmission:
Compression:
Fuel:
Intake:
TB size:
Meth y/n:
Intercooler size:
ET/mph:
RWHP:
RWTQ:
Here are some I have found from build threads:
Turbo: S475 T6 1.32 A/R 83mm turbine
PSI: 11 PSI
Cubic Inch: 347
Transmission: T56
Compression: Not listed (estimated 9.5:1)
Fuel: 93 pump
Heads: Patriot ported 243's with large valves 64 cc
Intake: LS6
TB size: 78mm
Meth y/n: Yes
Intercooler size: Spoolin Performance large core FMIC
ET/mph: N/A
RWHP: See graph
RWTQ: See graph
PSI: 11 PSI
Cubic Inch: 347
Transmission: T56
Fuel: 93 pump
Intake: LS6
TB size: 78mm
Meth y/n: Yes
ET/mph: N/A
RWHP: See graph
RWTQ: See graph
Turbo: Billet S475R 83/74 turbine 1.10 A/R T4
PSI: 22 PSI
Cubic Inch: 293 (4.8)
Transmission: not listed (assume 4L80E on GM truck)
Compression:
Fuel: E85
Heads: Stock 863 un ported
Intake: stock TBSS intake
TB size: stock 78mm
Meth y/n: No
Intercooler size: Not listed
ET/mph: N/A
RWHP: 877
RWTQ: 822
PSI: 22 PSI
Compression:
Fuel: E85
TB size: stock 78mm
Meth y/n: No
ET/mph: N/A
RWHP: 877
RWTQ: 822
Turbo: Cast S480 1.10 A/R 92 mm turbine (not sure T6 or T4)
PSI: 21 PSI
Cubic Inch: 347
Transmission: Not listed (4L80 I believe)
Fuel: E85
Heads: Stock 317's
Intake: Edelbrock Pro Flow
TB size: 78mm
Meth y/n: No
Intercooler size: Not sure
ET/mph: 9.77@140.40 in a 4,500 lb truck
RWHP: See graph (blue lines)
RWTQ: See graph (blue lines)
Blue lines, red lines were with old 4.8
PSI: 21 PSI
Cubic Inch: 347
Fuel: E85
Heads: Stock 317's
TB size: 78mm
Meth y/n: No
Turbo: Billet S480 96 mm turbine 1.32 A/R (T6 I believe)
PSI: 25 PSI
Cubic Inch: 347
Transmission: PG
Compression: 11.5:1
Fuel: E85
Heads: Ported 853
Intake: Viv Jr.
TB size: 105 mm
Meth y/n: not sure
Intercooler size: A2W
ET/mph:
RWHP: 1063
RWTQ: 823
PSI: 25 PSI
Cubic Inch: 347
Transmission: PG
Compression: 11.5:1
Fuel: E85
Heads: Ported 853
Intake: Viv Jr.
TB size: 105 mm
Meth y/n: not sure
ET/mph:
RWHP: 1063
RWTQ: 823
Turbo: S480 (T4 , A/R 1.25 , 87mm turbine wheel size, race cover)
PSI:20
Cubic Inch:364
Transmission:th400
Compression:8.2
Fuel: 100 unleaded
Heads: tfs 235 cnc
Intake: ls6
TB size: stock
Meth y/n: yes
Intercooler size: ebay 31x12x4 3''in/outs
ET/mph: 9.33 151 1.44
RWHP: only numbers i remember was 640 in 13 psi with low timing cuz i was out of injector
RWTQ:
PSI:20
Cubic Inch:364
Transmission:th400
Compression:8.2
Fuel: 100 unleaded
Heads: tfs 235 cnc
Intake: ls6
TB size: stock
Meth y/n: yes
RWTQ:
Would be nice to throw the cam used in there too...
Turbo: S400sx3 75mm t4 1.10 t4 83/74
PSI: 22 creeps to 25 by redline
Cubic Inch: 323 (5.3) (2001 stock orig. short block 160k)
Transmission: Power Glide
Compression: 8.6:1
Fuel: E85
Heads: OEM casting 317, VERY mild hand port.
CAM: ZR1
Intake: LS1
TB size: Stock
Meth y/n: n
Intercooler size: 32x12x4 CHeapy Ebay china IC
ET/mph: 8.93@ 153 1/4, 5.73 @ 122 1/8th
2850lbs
Compression: 8.6:1
Fuel: E85
CAM: ZR1
Intake: LS1
TB size: Stock
Meth y/n: n
2850lbs
Sub'd for this one I to will be running a billet s480 ETR HO V3 curious to see what these turbos are capable of. Also who ever would like to share additional info would be greatly appreciated weight of the car etc...
Turbo: s475 standard cover $650 version (96mm turbine,T6, 1.32a/r)
PSI: 17
Cubic Inch: 347
Transmission: t56
Compression: stock LS1 I think 10:1
Fuel: pump 93
Heads: 241 all in stock form
Intake: stock LS1
TB size: stock factory LS1
Meth y/n: Yes, Twin 10gph Nozzles using 100% VP Fuels M1
Intercooler size: Ebay 24/12/4" core a2a
ET/mph: Unknown
RWHP: 755
RWTQ: 663
Tuned by Aaron Lail @ TruDynoSports, Conover,NC.
Car is currently on 20psi. Still untouched 130000 mile LS1 besides the cam.
Heads never been off nor the Intake.
Dyno Graph. This was at a dyno/car event at Tick Performance
The Video
PSI: 17
Cubic Inch: 347
Transmission: t56
Fuel: pump 93
Intake: stock LS1
ET/mph: Unknown
RWHP: 755
RWTQ: 663
The Video
^ Comparing your results with post three:
him at 11 psi and you at 17 psi, but you have the same numbers. He's got ported 243's where you have stock 241's, but otherwise very similar. Wonder why he's making the same numbers at only 11 PSI? Dyno differences would be my first instinct but that's a big difference, non the less you've got a bad *** car there.
Here is a nice before and after. OP went from the budget S475 to a S476R, you can compare the differences between the two all though during the switch he also had the block rebuilt and bored it out a little and also bumped the compression a couple points:
Turbo: Cast S475 T6 96 mm turbine 1.32 A/R
PSI: 17 (no gain with more boost)
Cubic Inch: 338 SBF
Transmission: PG
Compression: 8.5:1
Fuel: E85
Heads: TFS 225
Intake: Edelbrock Vic Sr.
TB size:
Meth y/n: N
ET/mph:
RWHP: See graph
RWTQ: See graph
AFTER turbo upgrade
Turbo: Cast S476 T6 96 mm turbine 1.32 A/R
PSI: 19 (no gain above 19 PSI)
Cubic Inch: 347 SBF
Transmission: PG
Compression: 11:1
Fuel: E85
Heads: TFS 225
TB size:
Meth y/n: N
ET/mph: 5.52 @ 131.8
RWHP: See graph
RWTQ: See graph
Cubic Inch: 338 SBF
Transmission: PG
Compression: 8.5:1
Fuel: E85
Heads: TFS 225
TB size:
Meth y/n: N
ET/mph:
RWHP: See graph
RWTQ: See graph
AFTER turbo upgrade
Cubic Inch: 347 SBF
Transmission: PG
Compression: 11:1
Fuel: E85
Heads: TFS 225
TB size:
Meth y/n: N
RWHP: See graph
RWTQ: See graph
Yes its obvious that 76R puts out way more but the compression went from 8:5 to 11:1 on the improved setup. Wouldn't that make some difference? Just curious. I have the standard everything s475 and seeing the 850rwhp number from this turbo on basically the same cubes as I have is reassuring. Makes me think I can get at least that outta my turbo before its outta steam.
