What is the best intake manifold for a high hp boosted aplication
Old 12-29-2013, 12:43 AM
aacrios's Avatar
Default What is the best intake manifold for a high hp boosted aplication
Looking to swap my stock ls2 intake I want to know wish of the shelf intake is the best for high hp applications .
Attached Thumbnails What is the best intake manifold for a high hp boosted aplication-image-1564781716.jpg
Old 12-29-2013, 01:39 PM
01 WS6 6.0's Avatar
Ill be running the holley high ram and looking to make 1k+rwhp but that intake would be huge on that s2k. Have you considered a victor with an elbow?
Old 12-29-2013, 07:52 PM
aknovaman's Avatar
Fr8train has put down 1142 HP to the rear wheels with a stock LS1 intake and stock throttle body with a 408 cid stroker. IMO don't waste your $$ on those parts since you are shoving it in the cylinders anyways.
For the life of me this is the only video I can find of it.
Old 12-29-2013, 08:33 PM
Taubr Unit's Avatar
However could he have made another 100hp with a better intake is my question.
Old 12-29-2013, 09:22 PM
soundengineer's Avatar
could have definitely made a bunch more power with a better intake
boost is just a measure of restriction...
you can make more power, on less boost with a less restrictive intake
any single plane will make great power with forced induction
Sheet metal intakes are king, followed closely by stuff like the Holley Hi-Ram
also, in general, better with a Carb style throttle body when possible, and bigger is better
Old 12-29-2013, 09:30 PM
dreamls1's Avatar
I made 700whp with a ls1 intake.
Old 12-29-2013, 09:32 PM
aknovaman's Avatar
Understood.
I was just providing an example of how much power can be made with a stock intake and throttle body.
I would be satisfied with the 1142 and running low 8's in a full bodied and stock looking interior and driving it anywhere in the USA without a trailer.
Whatever floats your boat.
Old 12-29-2013, 11:19 PM
1BadAsZ's Avatar
Lol what he said ^^^^
Old 12-30-2013, 01:19 AM
Originally Posted by aknovaman
Understood.
I dont know what the part in red has to do with the intake...
lots of guys throw on a single plane vic jr with a low profile elbow and it looks stock from the curbside...and they drive it all over...
also, I have driven some pretty radical setups as a daily driver...and put more miles on it than some people do in their unmodified daily car.
Old 12-30-2013, 09:17 AM
OldGold's Avatar
I made 805 with an LS1 and a 78mm truck TB. It would have gone 900, but I was having voltage issues above 6200 that were basically putting an end to the power right there. I am swapping an LS6 on and will see if that makes a difference. I did this on 15.8 psi average boost and under 13* of timing through an unlocked 4L80E.
Mike
Old 12-30-2013, 09:25 AM
Preston99WS6's Avatar
Everybody always mentions the holley Hi ram, and leaves out the edelbrock proflo-xt IMO it is just as good of a piece, Seen plenty of FI cars pull hard over 7K with the proflo.
Old 12-30-2013, 09:28 AM
Mike
Ls1 to LS6 isnt that much difference...
even on a Naturally aspirated Motor, the only difference is that it carries out to a higher rpm...the curve follows almost exactly the same otherwise.
Old 12-30-2013, 09:41 AM
I didnt mention it because its not that good...
once you get down to the #'s, a FAST 92 does better
the proflow does marginally better in the upper rpms than an 85mm stock style intake(like that metal typhoon intake)...it doent usually pull past 6200/6400 rpm's....
I have seen a back to back with the Stock/proflow/fast 92.....the fast 92 out performed the proflow.
Old 12-30-2013, 10:02 AM
proflo does great when it has a cam speced for the runners, only comparisons I have seen was it vs a LS6 where the cam was speced for the LS6 runners and it didnt do as well in the mid range but did better up top. A fair comparison would be to run differents sticks as well one to take advantage of the composite intakes one to take advantage of the proflo runners hands down I bet the proflo would kick the fast 92/ LS6 teeth in. ITs all about the valve timing events with the longer runners.
Old 12-30-2013, 10:10 AM
OldGold's Avatar
What intake pulls clean and carries the power out to 7k and fits under a low hood?
Is it not worth it to pick up the LS6? Should I just stick with the LS1?
Mike
Old 12-30-2013, 10:12 AM
87silverbullet's Avatar
That's cool and all but can they run their stock hood, keep their cowl, and windshield wipers?
Old 12-30-2013, 10:14 AM
Mike
I say it is, LS6's will pull right to 7K not much higher, ls1's seem to be done around 6.5K, anyway its how I am going to roll as I dont want to cut the wipers out of my T/A.
Old 12-31-2013, 10:26 AM
Chevy406's Avatar
I've been halfway considering selling my Victor Jr, Accufab 4150, Extreme Velocity setup in favor of a Holley Hi-Ram. I guess it would mainly depend how much difference in cash I would have to come up with. I did some quick internet pricing and new cost is equal for a Hi-Ram + 102mm TB vs Victor Jr + 4150 Accufab + EV Pro hat (roughly $1080 for both setups).
I'll probably stick with what I already have - unless someone really wants it:
Old 12-31-2013, 12:50 PM
Twin turbo c5's Avatar
I'm a big fan of the truck intake and ls6 i've had both. Cant beat them for tha price.
Old 12-31-2013, 12:56 PM
DemonicZ's Avatar
I'm going with Super Victor 4150, Wilson Elbow, and Wilson LSX TB for my intake portion, I know those parts are pretty pricey but I'm in no rush to finish the build if it means spending more money on high quality parts.
Quick Reply: What is the best intake manifold for a high hp boosted aplication
