6.2 ls3 with s480
Old 01-06-2014, 08:17 PM
Hulkls1's Avatar
Default 6.2 ls3 with s480
I have a aluminum 6.2 ls3 with 317 heads I'm going with 96mm 1.32 ar s480 custom cam any body ever don't a 6.2 yet and what can the stock rod and piston can take ?
Old 01-06-2014, 08:25 PM
DEFYANT's Avatar
I would say 700rwhp wouldn't be a problem, Vette guys do that quite a bit.
Old 01-06-2014, 08:52 PM
mrstepheneades's Avatar
I'd like to see some big power out of these.
Old 01-06-2014, 08:58 PM
Hulkls1's Avatar
You think it will spool the big s480 good on the street?
Old 01-06-2014, 09:22 PM
Twin turbo c5's Avatar
Oh yes it'll spool it easily. Should be nasty fast!!
Old 01-06-2014, 10:09 PM
Hulkls1's Avatar
We will find out soon shooting for 800 hp
Old 01-06-2014, 10:22 PM
My6speedZ's Avatar
I think an LS3 is pretty close to the perfect size for an S480.
Old 01-07-2014, 12:04 AM
9 Second Truck Club
stock48's Avatar
The pistons and rods are just as strong as a lq4/9. The block is a little weak but should hold about same as the rotating assembly. 800 should be no problem. One thing I have found with the 6.2's is the rings are really tight gap from the factory might want to look into that if it's a low mile engine.
Old 01-07-2014, 06:35 AM
Hulkls1's Avatar
It is low miles what should I gap the top ring to?
Old 01-07-2014, 07:23 AM
9 Second Truck Club
stock48's Avatar
Most 100K mile 5.3~6.0's are ~.022'' +. The 30K mile L92 I just tore down was .015''. I would want at least .022'' if I was going to boost it hard.
Old 01-07-2014, 07:59 AM
Hulkls1's Avatar
I see that's the 6.2 is 10.7.1 with 70 cc heads that's kinda high isn't it?
Quick Reply: 6.2 ls3 with s480
