Back pressure with 80mm turbo
Old 01-13-2014, 07:24 PM
Daniel Nicastri's Avatar
Default Back pressure with 80mm turbo
Just seeing if anybody out there has any info on using a s480 billet wheel with a 1.56 a/r on a 408 lq9
Old 01-13-2014, 08:15 PM
mike13's Avatar
Do you know what size turbine wheel it has? It's all relative, if your trying to make 800+ than it's going to have a lot of back pressure, 650 not so much. Also on the S480 there is a few different combinations especially on turbine wheel size.
Old 01-13-2014, 08:21 PM
mike13's Avatar
I don't want to do the jerk move of saying do a search but in this case search for the S480 lots of good info, especially on S480 and engine size matching.
Old 01-13-2014, 08:46 PM
slowlsx's Avatar
You'll be fine
Old 01-13-2014, 10:18 PM
All I know is its a forced induction billet 80mm wheel
Old 01-13-2014, 11:35 PM
slowlsx's Avatar
If its the 96/1.32 youll be fine!
that's a cast 80mm abd 427. He holds the ultra street record
Old 01-14-2014, 04:58 AM
I hope the 1.56 A/R helps , it needs to make more then 1000rwhp
Old 01-14-2014, 09:07 AM
mike13's Avatar
Just depends on the turbine wheel.
Old 01-14-2014, 09:31 AM
slowlsx's Avatar
More then likely has a 96 woth that size AR. John keesey went 5.0x qith the Cast version
Old 01-14-2014, 05:16 PM
96 inducer 88 exducer if that helps
Quick Reply: Back pressure with 80mm turbo
