Tick Performance LT1 turbo build 907rwhp/860rwtq 19psi
Old 01-19-2014, 04:18 PM
Sales@Tick's Avatar
Thanks guys! I wish it was a C7 too! LOL!
Old 01-20-2014, 07:45 AM
glocklimited9's Avatar
Martin the work you guys do at tick is always impressive, car should really boogie, really killer setup
Old 01-20-2014, 08:03 AM
forcd ind's Avatar
cool project, cant wait for the final #'s
Old 01-20-2014, 10:43 AM
Sales@Tick's Avatar
Thanks for the kind words!
Old 01-21-2014, 10:19 PM
TravisA's Avatar
Nice build! Can't wait to see the #'s it puts down!
Old 01-22-2014, 12:00 PM
Rob94hawk's Avatar
Love those splayed mains and all that nice hardware! Looking forward to the dyno results!
You gonna ceramic coat those huge exhaust headers?
Old 01-22-2014, 03:58 PM
Sales@Tick's Avatar
I don't think we're going to coat them, maybe.
Old 01-23-2014, 07:38 PM
ReggieWarrenJr's Avatar
Sweet Build! That WG merge is awesome! I'm also doing a turbo LT1 build, 396ci with a comp CT6 91mm. I wish I had a dollar for every time someone said its going to blow up because it a LT1! lol. Not many people respect or realizes how much power they can actually make!
Old 01-23-2014, 08:26 PM
hawk584's Avatar
if you guys build the transmission for my LT1 Firehawk even 1/2 as awesome as your entire car i will for ever be in your debt! .. I believe it was delivered on the 22 Jan
Old 01-24-2014, 12:01 PM
Tjabo's Avatar
Jaw-droppingly nice build there, so I'm not meaning to throw stones. BUT, I was really hoping you were going to spout an HP goal that is a lot more than 800rwhp.
It seems hard to justify the coin that went into this build unless it ends up making a lot more power than that. What with the low-buck builds on this forum that make power in that range for very little money, and all... No?
Such beautiful work though!!!
Old 01-24-2014, 03:16 PM
Sales@Tick's Avatar
They really need the 4 bolt main upgrade, but once you do that they are pretty strong. Having 5 bolts per cylinder helps with deck sealing as well vs. a LS engine.
LOL!
This car already had a ton of this stuff done to it. We built this car as a 383 stroker for nitrous years ago. 24x was done then as were all suspension, drive train and other upgrades.
We fortified the engine, fabricated the turbo kit and upgraded the trans from a level 2 to a level 3 this go around.
We have never pushed a LT1 this far before so we don't want to shoot for the moon before we even fly if you catch my drift.
800rwhp is a ton of power, and it will be a dead nuts reliable 800rwhp. Not a ticking time bomb stock bottom end engine that could spew its guts at any moment.
Old 01-24-2014, 03:24 PM
  #32
Tjabo's Avatar
True true, I get you, sweet build!
Old 01-25-2014, 11:24 AM
  #33
2000RATA's Avatar
Exactly! Finally someone said it! Too many idiots here think every JY motor will make 800+ RWHP every time, every build, and be reliable. They ignore all the threads where someone kills these on way less power.
Love seeing someone doing something with the LT1! Lots of 425+ RWHP LT1 N/A guys around here. No reason a turbo on top of that can't get it done!
Old 01-27-2014, 08:34 PM
  #34
robsquikz28's Avatar
I had well over 850hp on my turbo build LTX with forged internals, 383 Afr heads and ported lt4 intake. 4Ljunk60e and strange Diff.
Boost was at 19lbs and could have made more power. Was on 80lb injectors and twin pumps. Needed to bump up to 95lbers or add some meth to mix. This was done on 93 and No meth.
Old 01-27-2014, 08:46 PM
  #35
Moderator
BizZzatch350's Avatar
Originally Posted by ajrothm
Nice build... Glad to see someone building an LT1 for a change... Car should fly!
Agreed, Great looking build, at that power level it should be an awesome ride.
Old 01-27-2014, 09:48 PM
  #36
zz17iroc's Avatar
Good luck with the build. You don't always have to go LSX to make power.
Old 01-27-2014, 10:06 PM
  #37
mrstepheneades's Avatar
I need some of that realible stuff lol. Stock engines as I have at 800+ power levels are grenades with pin pulled. I'll get reliable one day.
Old 01-28-2014, 08:17 AM
  #38
Sales@Tick's Avatar
Thanks guys! 800rwhp is what we're shooting for on pump gas/meth, but we do have a 55 gallon drum of C16 sitting here that can be put to use at a moments notice!
Old 01-31-2014, 06:46 AM
  #39
Tickfab's Avatar
For the ones asking about horsepower, we are shooting for 800 rwhp but if we go over a few we aren't going to complain. However this is a daily driver and the owner is making the call on power.
Should he want to test the power limit of the block we have used a turbo that should be able to get past the 1000 rwhp mark.
I have seen sbc engines broken from shear power before, not sure if you can put the LT1 block in the same class but it is possible.
Old 01-31-2014, 01:08 PM
  #40
notenoughmoney's Avatar
I need to order a cam, I have called tick 3 days in a row to only get a VM box that claims to be full ???
Quick Reply: Tick Performance LT1 turbo build 907rwhp/860rwtq 19psi
