truck turbo manifolds ???
Old 01-22-2014, 05:53 AM
jaywill's Avatar
Default truck turbo manifolds ???
what's better header bolts or stock bolts ???
Old 01-22-2014, 06:42 AM
HexenLord's Avatar
Use stock if you still have them.
Old 01-22-2014, 07:18 AM
x275radial's Avatar
i used arp studs work 10 times better than anything
Old 01-22-2014, 07:28 AM
ls1_chevelle's Avatar
The ARP header stud kit is the way to go, but its pricey, 130 or so.
Old 01-22-2014, 07:46 AM
krwyellowZ28's Avatar
Stock bolts break on stock vehicles alllllll the time... if you're hanging a turbo or two I would definitely use something better.
Old 01-22-2014, 08:25 AM
HexenLord's Avatar
Obviously don't reuse the stock bolts if they are rusted. A single grade 8 bolt is strong enough it will support the weight of an entire turbo/exhaust. You can. Order a full set of grade 8 bolts in the size you need for 10% of the cost of ARP studs.
Old 01-22-2014, 08:52 PM
jaywill's Avatar
I have the bolts that came with my pacesetter headers ...they r good enough ?
Old 01-22-2014, 10:34 PM
HexenLord's Avatar
They aren't holding a ton of weight. I don't know where you got the idea that your bolts wouldn't be good enough.
Old 01-23-2014, 01:39 AM
Moderator
denmah's Avatar
i always re use the stock bolts
stock 10 and 13mm work great in high hp applications for years and thousands of miles, honestly ive only NOT used stock bolts once, since i didnt have them for a build, and i used some 8 dollar ebay bolts from pots performance.
no leaks, breaks, or problems
Old 01-23-2014, 07:50 AM
stevieturbo's Avatar
I cut up some stainless bolts to make studs.
Much nicer all round, and always stronger.
Old 01-23-2014, 02:20 PM
jaywill's Avatar
Got ya !
Old 01-23-2014, 04:46 PM
sbcgenII's Avatar
If you don't use fancy bolts your manifolds will blow off your engine!!
Old 01-23-2014, 05:08 PM
73turbo53's Avatar
Stock bolts all day, they have a great flanged head.
Old 01-23-2014, 05:25 PM
Sumter's Avatar
I use the Alper Motorsports stainless header studs for $18.50 shipped
Old 01-23-2014, 05:29 PM
Chevy406's Avatar
Actually, stainless steel has less carbon content and is thus weaker than carbon steels. Stainless is also very bad to gall. I would not use stainless bolting on exhaust manifolds.
Quite frankly, I don't know why anyone would have a problem using stock exhaust manifold bolts.
Well, I guess that's a good reason.
Old 01-23-2014, 06:35 PM
jt76's Avatar
I'm switching to studs.. factory bolts started to back out on me and a couple holes stripped.. a bit too much weight perhaps.
Old 01-24-2014, 05:32 AM
Nobody said they had a problem. But studs are far easier. Strength isnt an issue regardless of steel type used.
Old 01-24-2014, 06:34 AM
Blowerman's Avatar
This is something I would normally say.
Old 01-24-2014, 07:41 AM
I should pull my head studs out too. Stock bolts are better.
One has to understand the reason why studs are used to justify using studs... ARP only offers them in stainless for the LS engine, if they offered carbon, Id be all over it.
When you hang a turbo kit off of manifolds with a brace or without and expansion and contraction... it puts lots of stress on the bolts, when you crank the poor bolt into the head, its really stressing the threads. But like I said, if you don't understand studs, you don't understand the reason.
Just like ebay headstuds, many use em, lots do not. You will be fine either way(within reason). Personal preference
Old 01-24-2014, 08:03 AM
Chevy406's Avatar
You make a good point about the value of studs ls1_chevelle, and I can appreciate your sense of humor. I would caution against using stainless steel studs and stainless steel nuts. If ARP only offers SS studs I hope they supply them with a dissimilar metal nut? Stainless-on-stainless is just a bad combination for galling.
I cut up some stainless bolts to make studs. Much nicer all round, and always stronger.
Slightly contradictory but you are correct that over stressed bolt failure isn't a common problem on exhaust manifolds. No doubt stainless studs have enough strength to work, I was just pointing out that they aren't stronger than carbon steel.
Quick Reply: truck turbo manifolds ???
